Author Topic: A Heron's Many Faces  (Read 2250 times)
Mongo
« on: November 04, 2018, 01:06:41 »
For some reason, the zoo in Port Douglas only comes in dark and darker. Much of the birdlife is under extreme shade from a very heavy canopy of trees. Light is precious and sparing.
This healthy specimen was shot in this environment with D810, 200-500mm @ 200 to 320mm, f8, 1/60th, ISO 250, -0.7 EV and built-in flash at -0.7EV also. Mongo strapped tightly to a tree.
Not sure if this is a grey heron. The colour of the beak has caused some doubt unless this is an age related trait only. Happy if someone could confirm
beryllium10
Re: A Heron's Many Faces
« Reply #1 on: November 04, 2018, 03:39:18 »
Nice images Mongo.  At first I didn't spot that they were done with on-camera flash - the dark backgrounds work well.
Our blue herons are scattered all around Seattle at the moment.  They won't gather and start nest-building at the nearby rookery until March.
Cheers,  John
« Reply #2 on: November 04, 2018, 08:10:28 »
Interesting images, thanks for sharing  :)
I like the last, taken from the front.
Mongo
« Reply #3 on: November 04, 2018, 09:17:36 »
thank you John and Bent for your comments - much appreciated.
« Reply #4 on: November 04, 2018, 09:20:05 »
Love the last two!  As always, I like the way you capture the "intentions" of the birds.
Nikkor Shooter
« Reply #5 on: November 04, 2018, 13:28:28 »
Very cool stuff, Mongo… very!   :D
Through an adjustment layer, if the second take had the bird raised
the shadows to brighten it up a tad, that shot (my favorite) would
reach great heights! Bravo!
jgould2
« Reply #6 on: November 04, 2018, 14:31:04 »
Hi Mongo.
Very well done. Crisp, sharp photos. Personally I like the dark backgrounds as they show off the bird even more.
JIM
Bill De Jager
« Reply #7 on: November 04, 2018, 19:57:35 »
Really well done, Mongo.
« Reply #8 on: November 05, 2018, 00:13:09 »
Excellent balancing of of fill flash with the available light.  Did you have the flash set to a fixed output, or was it running on an automatic or TTL setting?
Mongo
« Reply #9 on: November 05, 2018, 01:27:31 »
thanks Akira. The last one seems to be popular with many. It must be the unusual perspective. You are right. Mongo loves studying the facial expressions of creatures generally. It often gives away what they are thinking …or as you say, their intentions. Believe it or not, this is quite important to give you notice and to be prepared to capture that take off, imminent squabble or other photographic event.
Nikkor Shooter. Big thanks for your comments and CC. The image was originally darker. Mongo did some layer work to raise the light primarily on the subject bird only. This was done for two reasons. first, it brought out sufficient detail in the bird without over exposing it in its naturally dark environment. Secondly, by leaving the background virtually as dark as it was, it created a good background contrast/differential against which the bird could better stand out….but subtly.
thank you Jim and Bill for your kind comments.feedback.
Thank you Keith for your comments and question. Mongo finds that in this fairly extreme light environment, you cannot really trust the flash auto settings not to be fooled. For this reason, Mongo always uses manually adjusted output settings both on the flash and the camera. As a general rule, Mongo finds that the auto settings on the flash are too harsh because it is trying to over compensate what it perceives as a very dark environment. Mongo’s flash is set to TTL mode but virtually permanently set to -0.7 or -1.0 EV for all situations. This tends to give a better balanced “fill flash” look. Now and then, have had to drop output even more to say, -1.3 to -1.7 EV. Sometimes, a couple of test shots are needed to get this as correct as possible.
In the images above, BOTH the camera and the TTL flash were set to   -0.7 EV.
« Reply #10 on: November 05, 2018, 02:12:26 »
Really like #1
« Reply #11 on: November 05, 2018, 12:20:05 »
Mongo did well!
The first one is my favorite, too.
Thomas Stellwag
« Reply #12 on: November 05, 2018, 16:22:38 »
the whole series is great, my fav is the last one, first time I see a real rubber neck  :)
Thomas Stellwag
David Paterson
« Reply #13 on: November 05, 2018, 19:19:32 »
These are lovely and I'll admit my favourites are the more conventional poses in #1, 2 and 4. Beautiful colour, and perfect tonal range from what were most likely perfect exposures.
Mongo
« Reply #14 on: November 05, 2018, 22:35:11 »
Thank you Armando, Jakov, Thomas and David for your kind comments.
BTW - had a play with a friend's new PF 500mm F5.6 yesterday and must say, initial impressions are very impressive. Mongo will wait for the 600mm versions.
