Author Topic: Cedar Waxwing  (Read 6569 times)
Cedar Waxwing
« on: October 17, 2018, 13:48:24 »
Nikon D4 ,Nikkor AF-S 600mm f/4G ED VR
1/1000s f/7.1 at 850.0mm iso1250
Re: Cedar Waxwing
« Reply #1 on: October 17, 2018, 15:14:58 »
Amazing  :)
Re: Cedar Waxwing
« Reply #2 on: October 17, 2018, 16:34:56 »
Nice shot!
Re: Cedar Waxwing
« Reply #3 on: October 17, 2018, 16:37:39 »
Stunning shot!
Re: Cedar Waxwing
« Reply #4 on: October 17, 2018, 16:43:51 »
A bird shot with points of interest other than the bird itself is always a pleasure to see.
In this case the action with the berries and the colorful background make the image for me.
Congrats.
elsid
Re: Cedar Waxwing
« Reply #5 on: October 17, 2018, 17:52:09 »
Excellent capture Robert. You never stop to amaze us with your Photos.
Re: Cedar Waxwing
« Reply #6 on: October 17, 2018, 17:53:57 »
A bird picture with something extra to recommend it :D
Re: Cedar Waxwing
« Reply #7 on: October 17, 2018, 19:34:19 »
Oleeee. Emotional. Vivid. Alive.
Re: Cedar Waxwing
« Reply #8 on: October 17, 2018, 19:44:37 »
excellent. Love your work!
Re: Cedar Waxwing
« Reply #9 on: October 18, 2018, 00:30:40 »
Timing is all!
Kuri
Re: Cedar Waxwing
« Reply #10 on: October 19, 2018, 06:01:58 »
This is perhaps the best wildlife/bird photo I have ever seen. Exquisite.
Re: Cedar Waxwing
« Reply #11 on: October 19, 2018, 10:02:30 »
Excellent IQ  ;)  Superb!
However I suggest you look at using this stellar lens without TC, and try cropping instead and look at the difference in the out of focus areas, Bokeh suffers here again, these double line type halos really distracts.
Nikkor Shooter
Re: Cedar Waxwing
« Reply #12 on: October 19, 2018, 10:27:19 »
Same thing here. I did try plenty of proposed solutions in the TC
world but found nothing that keeps the cosmic sharpness of this
old 600mm… working so well on all my 5 bodies.
Cropping is less an option with the single digit bodies. That is
why I went the D850 way.
Spectacular rendition, Bob! :P
Re: Cedar Waxwing
« Reply #13 on: October 19, 2018, 11:25:50 »
where i am (wildlife is not that close - or you can't get that close) cropping is not a very good option especially with a lower megapixel cam like the D4 here..  as the loss of detail is significant and a greater loss than the artifacts introduced by the TC..   so sometimes it is a matter of getting a shot or not and suffering the background artifacts.
i have plenty examples using the TC that were completely acceptable.. so it is hard to know when and where not to use it.. example below with D5 and the new 600/E FL (could be the old lens was more susceptible to this.. as you indicated in the wood duck shots, which was the old 600/G and is used above)
i agree that the cedar above has particularly bad artifacts - which i guess i should clone out when i get around to it. (will post result)
1/2000s f/8.0 at 850.0mm iso1800
this shot with new 600/E FL without a TC doesn't have the best background. i will search for other examples.
1/2000s f/9.0 at 600.0mm iso1600
bare 600/E FL with similar artifacts.. i should probably start a separate thread on this.
1/3200s f/9.0 at 600.0mm iso1000
1/320s f/9.0 at 600.0mm iso8000
this one is with the old lens/cam combo and doesn't have the artifacts..  or as much anyway..
1/4000s f/7.1 at 850.0mm iso2200
here is bare 600/E FL and cropped.. i am not impressed with this shot at all.. for detail or background.
1/3200s f/9.0 at 600.0mm iso5000
Re: Cedar Waxwing
« Reply #14 on: October 19, 2018, 11:48:21 »
Thank you, it is just an observation and an excuse to buy an 800mm, a D850 or both ;)
I also have good image quality for most scenes and combinations, but sometimes the TC just disappoint in the rendering,,, same with VR,,,
Thank you for your lovely images!
