Author Topic: Cosina Voigtlander 125mm 2.5 Apo Lanthar repair  (Read 3246 times)
Bjørn Solberg
« on: July 24, 2018, 10:53:49 »
Bought this http://nikongear.net/revival/index.php/topic,2711.msg39833.html#msg39833  a bargain.
But now I have a (small?)repair issue, the lens is a little loose where indicated on the photo.
(Photo used is borrowed from the seller)
Big issue to repair?
Re: Cosina Voigtlander 125mm 2.5 Apo Lanthar repair
« Reply #1 on: July 24, 2018, 11:28:01 »
Is the whole lens wobbling back and forth or is the focus ring loose, what do mean by loose?
Not a big deal to take it apart,,, just take care.
BTW i'm obviously the previous owner,,,
Bjørn Solberg
« Reply #2 on: July 24, 2018, 12:37:08 »
Thanks for reply,
Focus ring is tight only the end part  is wiggling a bit. Maybe it does not affect picture quality much?
Seapy
« Reply #3 on: July 24, 2018, 16:04:54 »
If it's just the bayonet mount then they do come loose, just needs tightening up?
Robert C. P.
South Cumbria, UK
« Reply #4 on: July 25, 2018, 09:15:18 »
Then it is most likely the next interface that is loose, below the mount.
It is of outmost importance that these three screws are tightened down, the risk of breaking this inner mount is rather high, it's the achilles heel of the design quite literally.
Three thin L shaped prongs go deep down into the lens and is held down by three tiny screws, tiny for such a heavy lens.
These are the three most famous screws,,,  :o   ;D
You see them clearly in image two in this old thread from or our ancestry site,,,
https://www.fotozones.com/live/index.php?/forums/topic/22738-repair-cosina-voigtl%C3%A4nder-sl-macro-apo-lanthar-125mm-f25/
Courtesy of Sten Rasmussen!
Bjørn Solberg
« Reply #5 on: July 25, 2018, 12:53:34 »
Thanks, I will post a new reply when the job is done. For time being I`m under the Vagrancy act (repealed 2004 in Norway) as homeless, Jis screwdrivers packed in boxes somwhere.
