Author Topic: Nikkor 50mm f/1.4, comments please.  (Read 1073 times)
Seapy
« on: May 17, 2018, 23:20:38 »
Normally I try to use a micro lens, 55mm f/2.8 or 105mm f/4 for photographing flowers to achieve a nice bokeh background but I found myself in a botanic garden without either, so I turned to my 50mm f/1.4 D,  This is one of the images I took. It's an HDR from three exposures because of the intense sunlight.
I am not really used to taking these sort of (intentionally) fuzzy pictures, I tried to get the flowers all in the focal plane, although some are out.  Have I got it right, or is there something I could have done better?
D3, lens wide open, hand held, it was quite breezy.
Robert C. P.
South Cumbria, UK
ArthurDent
Re: Nikkor 50mm f/1.4, comments please.
« Reply #1 on: May 30, 2018, 13:21:11 »
I have the 50mm f/1.4 AFD and I think it is a pretty good lens from about f/4 to f/8, maybe f/11. You might try using it again at f/4, get more dof, and see if the bokeh is still acceptable. I haven’t had much luck shooting hdrs on windy days, but maybe that’s a function of the software used, I usually use photomatix pro, for which otherwise I have no complaints. You could also try taking one of your shots, copying it twice, upping the ev on one copy by a stop and lowering it a stop on the other and make an hdr from the image and two copies. I’ve done that before and had decent results.
« Reply #2 on: May 30, 2018, 15:27:03 »
Apparently you found the best possible focal plane in the described situation.
However, I would get much closer to a single flower and push others out into the bokeh area.  The multiple blurred flowers will be descriptive enough to give the viewers the impression of the full bloom, and blurred leaves should offer a pleasant green background.
« Reply #3 on: May 31, 2018, 01:07:41 »
What I see:
I'm not seeing the typical HDR tone-mapping artifacts...that's a good thing, right? The shot has a natural, 'bright sunny day' look.
The blurry stuff behind the subject is distracting.
The out of focus rendering of a 50/1.4 and other fast lenses when used wide open can be unpleasant at times. This, IMO, is one of those times.
Trapped as you were with that one lens, there is no satisfying solution here unless you could have eliminated the clutter caused by the background and it's rendering by the lens.
Seapy
« Reply #4 on: May 31, 2018, 07:07:04 »
Thank you gentlemen,  I am taking more and more to using HDR when bright lighting is pushing the lighting range, Lightroom makes it so easy and the results seem to be pretty natural, I was put off by the garish results from earlier HDR methods but now it seem much better.
I realise that the flowers, several of which are well past their best aren't particularly pretty but it was an attempt, an experiment if you like, to emphasise the flowers and separate them from their background.  In my eyes I failed to make a decent picture.  Looking at it afresh, I should probably have waited until I had the tripod and a micro Nikkor lens, then concentrated on a much smaller part of the branch.  I really wanted to capture the characteristic of that plant of it's pendent flowers in rows.  The odd dead flower or bud is fine, that's life, warts and all!
In future I will try various apertures, I enjoy the 50 1.4 but  it has to be used carefully, I was expecting too much here, I can see that now.
Perhaps a more distant shot to show the habit, then a close up of a small bunch of flowers to show the detail and beauty of the individual blooms.
Once again thank you for helping me understand the image better and consider alternative ways of approaching it.
Robert C. P.
South Cumbria, UK
