Author Topic: The Nikkor “O” CRT 55mm f/1.2 Lens: A Recipe for Lovely  (Read 31971 times)
Re: The Nikkor “O” CRT 55mm f/1.2 Lens: A Recipe for Lovely
« Reply #75 on: September 21, 2024, 11:06:56 »
Here it is.
Upper photo: on 17-31mm extension, which allows for infinity focus on the Z system.  There will be some corner vignetting on the FX bodies thus I more often use the 55 CRT on DX format.
The slimmest solution will be an M42-M42 focusing helicoid, add a flat M42-Z adapter at the rear and insert the 39mm-42mm ring in front.
Below is the 55 CRT with my bespoke F adapter, complete with CPU. Can be used on F systems or on the Z via FTZ/FTZ.2 with EXIF information available, but only for close-ups.
« Reply #76 on: September 21, 2024, 13:12:21 »
Thank you!
So, what you are saying is I will need an M39-Z adapter and 17-31mm M39 extension rings in order to focus to Infinity? :o :o :o
« Reply #77 on: September 21, 2024, 16:38:27 »
M42-M42 helicoid and M42-Z flat adapter and the 39-42mm insert ring shown in my picture #2. Then you can witness for yourself that the 55 CRT never was designed for infinity focus :)
