Author Topic: Spider  (Read 3666 times)
Spider
« on: July 12, 2015, 20:28:10 »
Hi all,
I was trying to achieve a sort of "horror" look with this spider shot. I attach two shots from the same position, which have the flash differently placed and a slightly different crop.
Which one fulfills the "horror" brief best, if any? And of course any other comment you can give me to improve. Thanks.
Re: Spider
« Reply #1 on: July 12, 2015, 20:38:36 »
Second one is that a strong flashlight? Looks like sitting on a filmset
Re: Spider
« Reply #2 on: July 12, 2015, 21:50:43 »
Thanks Frank.
Yes, both with flashlight. 1st one from top, a little from the back. 2nd one from righthand side, slightly below spider level.
Re: Spider
« Reply #3 on: July 12, 2015, 21:59:22 »
Obviously getting closer to any spider will trigger the arachnophobia better (or faster) ... so, #2, but even closer if possible.
Bjørn J
  • North of the Arctic Circle
Re: Spider
« Reply #4 on: July 12, 2015, 22:05:08 »
The second one brings me associations to Shelob in Cirith Ungol (Lord of the Rings for the uninitiated) :)
Bjørn Jørgensen
Re: Spider
« Reply #5 on: July 12, 2015, 22:45:54 »
Thanks, both Bjørns.
Bjørn R., of course, good pointer. I was trying to, but these guys (or girls) are in a sort of funnel and are not so big to start with. Every time i moved, i startled it and it disappeared into its funnel (i.e. out of sight).
I'll try how it works if i crop in more.
By the way, i wasn't necessarily after arachnophobia, but perhaps rather the eery feeling spiders can cause. It seems that i managed to surface some of that feeling with Bjørn J.
Thanks!
Re: Spider
« Reply #6 on: July 14, 2015, 19:51:19 »
Both are good, but I like the second one because more of the surroundings, and particularly the web, are  visible.  All without being flat lighting...very nice.
Re: Spider
« Reply #7 on: July 30, 2015, 14:19:07 »
I like both but the first one gives me more of the horror feeling, likely due to it being darker.
Re: Spider
« Reply #8 on: July 30, 2015, 16:28:38 »
Thanks Keith and Jørgen, much appreciated.
Re: Spider
« Reply #9 on: July 30, 2015, 21:05:25 »
This is definitely a male.
The second one is my favorite (better light).
It's very easy to play with these creatures :  feed them with a fly or cricket (they must be alive) but make sure you are ready to shoot ! ;D
Re: Spider
« Reply #10 on: July 31, 2015, 09:41:43 »
Thanks, i wouldn't have any idea how i could see the difference.
Thanks for your comments.
I bet a cricket would eat it, as it is only about 1 cm (or so) big.
Re: Spider
« Reply #11 on: July 31, 2015, 17:06:31 »
Very easy : Male looks like a boxer as both its pedipalps wear protuberance which the female doesn't. It's actually its copulating organs as it has no penis.  :-[
Spider doesn't mind to fight with prey 3 or 4 times bigger... :P
