Author Topic: ENTANIYA high resolution fisheye lenses  (Read 2497 times)
« on: January 27, 2018, 10:34:07 »
Found this by coincidence, NASA used those, but they offer also commercial products:
http://products.entaniya.co.jp/en/products/
Not cheap at JPY328.000-398.000
HAL200 and HAL250 are especially interesting:
http://products.entaniya.co.jp/en/products/hal-250200/
Products and samples may be seen on their flickr site:
https://www.flickr.com/photos/134236788@N08/
Resolution and lack of color fringing (CA) is rather impressive indeed.
Examples taken with different sensor sizes:
All images (C) ENTANIYA
Re: ENTANIYA high resolution fisheye lenses
« Reply #2 on: January 27, 2018, 10:44:55 »
very interesting klaus... thx for the link!
« Reply #3 on: January 27, 2018, 11:46:11 »
Interesting Product. But 3500 US$ for a MFT-lens???
« Reply #4 on: January 27, 2018, 13:30:37 »
Interestingly the image circle of Sigma 4.5mm circular fisheye for APS-C format is 12.3mm.  Theoretically it should work also on a m4/3 camera with 17x13mm sensor as circular fisheye via an appropriate adapter.
« Reply #5 on: January 27, 2018, 14:56:53 »
It does. Tried on my Panasonic GH-2 bodies. You need to have the field limiter ring on the lens, though, so angle of view is not 180 degrees.
« Reply #6 on: January 27, 2018, 16:13:37 »
Thank you for sharing your experience, Bjørn.  The necessity of the field limiter ring may suggest that the actual image circle is larger than indicated and more than 13mm?
« Reply #7 on: January 27, 2018, 18:36:30 »
More like there is this rather fuzzy peripheral part of the image that doesn't contribute much to the overall impact. Also might lead to cutting off the image circle, so adding the ring that comes with the lens (acts as a protection, and a mounting platform for a lens cap) is recommended.
Those Entaniya fisheyes are quite intriguing, I'll have a look at the product range after the upcoming move out of Oslo that hopefully does double duty by improving my economical situation :D
« Reply #8 on: January 27, 2018, 19:32:40 »
Indeed, it always disturbs me too and adds quite some time to get rid of...
Well, how about buying a lottery ticket then? :-)
