Author Topic: Roman Hangover  (Read 2223 times)
Ron Scubadiver
Roman Hangover
« on: January 11, 2018, 05:59:36 »
Roman Hangover by Ron Scubadiver, on Flickr
24-120 @ 24mm, stitched in ACR.  Distortion is caused by stretching an imperfectly aligned series of photos to fit a rectangular frame.
Re: Roman Hangover
« Reply #1 on: January 11, 2018, 08:20:47 »
Interesting thought that it was because of the earth has moved ::)
Nice picture :)
Re: Roman Hangover
« Reply #2 on: January 11, 2018, 11:48:16 »
Definitely not a keeper for me. No way to change the stitching parameters and avoid distortion ?
simato73
Re: Roman Hangover
« Reply #3 on: January 11, 2018, 13:22:15 »
I am with MFloyd on this.
The pano could be interesting but it is very unevenly stitched and full of distorsion.
Simone Tomasi
Re: Roman Hangover
« Reply #4 on: January 11, 2018, 16:23:37 »
If stitched in ACR then you can use the adaptative wide angle filter in PS and fix the lines, perhaps you need to redo the stitching from inside PS
Ron Scubadiver
Re: Roman Hangover
« Reply #5 on: January 11, 2018, 21:06:26 »
I was trying to get a distorted look.  Perhaps if it the distortion was extreme it would work better as some are interpreting it as a mistake rather than an artistic expression.
Re: Roman Hangover
« Reply #6 on: January 11, 2018, 21:53:48 »
Ron, you may want to exaggerate the distortion, which would make the image more interesting?
Am I observing a kind of "W-shape" distortion?
Ron Scubadiver
Re: Roman Hangover
« Reply #7 on: January 11, 2018, 22:02:48 »
W sort of.  Exaggerating it is an idea.  I will have to try that, but probably with a different image.
Re: Roman Hangover
« Reply #8 on: January 11, 2018, 22:24:28 »
Am looking forward to seeing it!
Re: Roman Hangover
« Reply #9 on: January 11, 2018, 23:55:06 »
Make it worse. You may start a new trend!  :D
