Author Topic: D800 Monochrome Conversion  (Read 8699 times)
Re: D800 Monochrome Conversion
« Reply #15 on: December 21, 2017, 14:17:54 »
cropped..
100%
« Reply #16 on: December 21, 2017, 15:12:06 »
the results i posted on the D800 comparison were in error.. the D800 was not as shown previously and was in fact sharper than i posted....  will do a proper comparison soon.
« Reply #17 on: December 21, 2017, 18:07:00 »
#16 converted vs unconverted look worlds apart. thank you for the lead!
« Reply #18 on: December 21, 2017, 19:23:40 »
Bob, the image looks promising.  Are you going to shoot landscapes with some contrast filters for B&W films like the orange or the red ones?
Those filters should reduce the haze effect in the distant scenes dramatically, but cause significant reduction of resolution due to the loss of data of the blue and green channels.   Even a more modest yellow filter does.
Kuri
« Reply #19 on: December 21, 2017, 19:24:29 »
Bob, Quite exciting and interesting! This is going to be enough to keep you busy for a while.  :-)
« Reply #20 on: December 21, 2017, 19:51:26 »
how's this..
Nikon D800 Monochrome,Carl Zeiss ZF2 / ZE / Zx Distagon T* f2.8 15mm
1/160s f/8.0 at 15.0mm iso100
« Reply #21 on: December 21, 2017, 19:52:24 »
1/500s f/5.6 at 15.0mm iso100
« Reply #22 on: December 21, 2017, 19:53:32 »
1/200s f/8.0 at 15.0mm iso100
« Reply #23 on: December 21, 2017, 19:59:11 »
« Reply #24 on: December 21, 2017, 20:05:46 »
It looks very good, specially the second one of the series with the trees through the square opening on the right -love it- and the counter tree through the small round opening on the left. Nice balance. The repetitive shadow pattern looks very good from far away from the screen -you made me move  ;D- and the amount of detail looks impressive even here. How does it looks with all the detail at your disposal?
« Reply #25 on: December 21, 2017, 21:24:26 »
I am very impressed with this conversion. The increased in both resolution and shadow detail is incredible. It seems to provide a 3d effect as well.
« Reply #26 on: December 21, 2017, 21:33:45 »
1/250s f/8.0 at 15.0mm iso100
« Reply #27 on: December 21, 2017, 22:05:06 »
Nikon D800 Monochrome ,Carl Zeiss ZF2 / ZE / Zx Distagon T* f2.8 15mm
1/200s f/8.0 at 15.0mm iso160
« Reply #28 on: December 21, 2017, 22:48:20 »
What is the spectral sensativity of the converted D800? Does it make a good B&W IR camera with approperate filter on the lens?
« Reply #29 on: December 21, 2017, 23:44:20 »
i was told by Maxmax that the loss of the micro lenses degrades the IR response. so i chose to put a BG-38 filter on the sensor that blocks IR.
