Author Topic: [Theme] Higher magnification: the tasty and the disgusting ...  (Read 5265 times)
The first pictures serve to get an idea of the scale (tip of a tooth pick) and the range of DOF (fully open / fully closed, trading DOF for detail resolution).
I did measure it now it is 9:1, 4mm pictured on a 36mm frame
Re: [Theme]
« Reply #1 on: December 12, 2017, 10:00:48 »
then a few beautiful edible plants and a British style wine gum sweet with lettering:
Re: [Theme]
« Reply #2 on: December 12, 2017, 10:03:10 »
And to close the first set, some dust from the "clean" bathroom and some ?whatever? ask a biologist ...
obviosly "cleanlyness" is a function of magnification ...
Re: [Theme]
« Reply #3 on: December 12, 2017, 11:31:23 »
Frank, this is an interesting thread.  Please edit the title to make it recognizable  8)
Re: [Theme]
« Reply #4 on: December 12, 2017, 12:14:29 »
New worlds. Edibles from close up do not look that edible...food for thought  :)  Interesting thread Frank
Re: [Theme] Higher magnification: the tasty and the disgusting ...
« Reply #5 on: December 12, 2017, 15:52:37 »
yes, Paco, food for thought and stomach.
Akira: Did cut title instead of copy! Corrected!
PS Do you recognize the food stuff???
« Reply #6 on: December 12, 2017, 17:22:43 »
Thank you, Frank.  Here is my expression of gratitude in a bizarre way.  Nikkor-O 55/1.2@2.8, reversed for around x5 magnification.
« Reply #7 on: December 12, 2017, 20:52:23 »
"Cleanliness is a function of magnification"
Frank, you have coined a new aphorism !
Cool shots... did you try increasing the contrast at all?
« Reply #8 on: December 12, 2017, 21:04:16 »
Akira: super shot of a ball pen,,, bloody writing tool!
« Reply #9 on: December 12, 2017, 21:06:29 »
not enough contrast? I thought I had overdone it already!
« Reply #10 on: December 12, 2017, 22:04:23 »
Interesting theme and a good start. Very good idea.  It looks like you started to use the PB-4 ...
« Reply #11 on: December 12, 2017, 23:15:38 »
Some insect or arachnoid mummy I found this morning (rougly half a millimeter in length).
1) space edit
2) original colors
Matthew Currie
« Reply #12 on: December 12, 2017, 23:43:47 »
Steinheil Culminar 60/4.5 on two sets of K tubes looks at tasty slice of bread:
« Reply #13 on: December 13, 2017, 00:32:01 »
yes later in the Shooting. in the beginning I used extension
the lens is a 25mm Biotar I found on ebay cheaply a while ago
Matthew Currie
« Reply #14 on: December 13, 2017, 01:09:58 »
Time to chow down on a nice little snack of death apples... (e.t.a. Schneider Componon 28/4 on a single stack of K's, D7100, cropped)
