Author Topic: Tokina 28-70mm f/2.8 ATX Pro  (Read 5235 times)
« on: November 05, 2017, 12:45:29 »
I had this lens around 10 years ago. It was built very well, was reasonably sharp wide-open from 28-50mm but is kind of poor at 70mm.
f/4 brings everything up to the same level, very sharp from here on. I love this lens a lot and I bought another one recently because I missed it.
I shot photos for billboards back in the day with this on the D90 ::)
I had the Pro II before and now I got the Angeniux-based one. :o :o :o
how about you guys, do you like yours?
Re: Tokina 28-70mm f/2.8 ATX Pro
« Reply #1 on: November 05, 2017, 18:37:58 »
Here's the Tokina version of "thousand and one night":
http://www.pictavern.com/column/detail?no=1246
Sorry, the text is in Japanese.  According to this, Angenieux one was manufactured by Tokina.  So, Angenieux was Tokina-based.  The author doesn't mention whether there was any optical difference between the A and T.
« Reply #2 on: November 06, 2017, 16:01:48 »
thanks! i read it!  :o :o :o
« Reply #3 on: November 06, 2017, 16:02:19 »
i am loving the lens. this was such a hot item back in the day  :o :o :o
« Reply #4 on: November 06, 2017, 17:01:11 »
Yeah, ATX Pro lenses may have been made better than the genuine AF Nikkors back then...
« Reply #5 on: November 07, 2017, 04:24:20 »
 :o :o :o
« Reply #6 on: November 07, 2017, 08:42:00 »
Looks quality made, i still have the 100mm f/2.8 macro with the similar slide up or down af/mf.
Thomas Stellwag
« Reply #7 on: November 07, 2017, 12:15:12 »
I had the 2.8  28-70 and the 2.8  80-200 of this series (my first FF lenses beside a 1.4  50mm AF, on D 700)
built like tanks, but CA worse than the comparable Nikkors
the info that the French top lens was made by Tokina, I heared the first time - is that sure?
I always thought Tokina bougt a license to copy the optical sheme into the 2.6-2.8 series
Thomas Stellwag
« Reply #8 on: November 07, 2017, 12:47:55 »
Briefly used the Tokina 28-70 until it split into two. A fellow photographer had the same happen to his 80-200. No more Tokina for either of us.
« Reply #9 on: November 07, 2017, 13:25:28 »
So the af/mf switch must be the vulnerable spot, i suppose, never liked that mechanism, somewhat reminiscent of the a/m ring on D lenses.
« Reply #10 on: November 12, 2017, 14:39:18 »
benveniste
« Reply #11 on: November 15, 2017, 03:53:24 »
I have the 3rd version (Pro II?) -- The f/2.6~2.8 with the bayonet lens hood.  Wide open, I find it's weakest at 28mm, pretty nice in the midrange, and slightly weak at 70mm.  Since I rarely photograph events it's one of my least used lenses.  For casual or "freestyle" shooting I typically use a 24-120mm f/4, and for more planned events I'll typically use a 17-35mm f/2.8 along with primes and/or a 70-200mm f/2.8.  I've owned quite a few Tokina lenses over the years.  I had a aperture linkage issue with one (a 20-35mm f/2.8), and found that a second was not a good fit for me (80-400mm f/4.5~5.6 without tripod mount).  But the others either gave me good service while I owned them (24-40mm f/2.8, 80-200mm f/2.8) or continue to do so today (60-120mm f/2.8, 90mm f/2.5 macro).
