Author Topic: Zeiss 28mm f/1.4 Otus - Some B&W  (Read 2775 times)
« on: October 31, 2017, 08:33:49 »
Re: Zeiss 28mm f/1.4 Otus - Some B&W
« Reply #1 on: November 01, 2017, 01:03:40 »
How do you compare these with the ones taken with the 15mm f/2.8 Distagon?
Sorry to flood the site with these images.
charlie
« Reply #2 on: November 01, 2017, 03:45:20 »
The 15mm starts stretching things towards the edges of the frame so I prefer the 28mm for its more natural rendering of the scene. Based on the images you've presented the 28mm appears to have a higher level of detail/clarity as well. Also the 28mm, when shot wide open, starts takes on a little bit of that large format film look with the wide-ish angle of view and shallow depth of field, as seen with your first picture of the color thread.
« Reply #3 on: November 01, 2017, 11:42:48 »
Thank you for the comment.
I think the same.
« Reply #4 on: November 10, 2017, 15:17:25 »
anxious to see more from that lens
« Reply #5 on: November 10, 2017, 15:18:32 »
i have noticed on the 15/2.8 Distagon that i have to keep it perfectly level to avoid distortion
Thomas Stellwag
« Reply #6 on: November 10, 2017, 16:00:13 »
you show an extraordinay atmosphere in these pictures
Thomas Stellwag
« Reply #7 on: November 10, 2017, 17:29:12 »
Thank you.
I believe that the clouds hiding some parts of sunlight add this atmosphere in the first picture.
« Reply #8 on: November 10, 2017, 23:02:46 »
I can't comment on the lens, but these are very dramatic images.
« Reply #9 on: November 10, 2017, 23:30:14 »
Thank you.
How life would be without some drama?   ;D
