Author Topic: Zeiss 15mm f/2.8 Distagon - Some B&W  (Read 3423 times)
« on: October 28, 2017, 14:10:35 »
Continuing to test this nice piece of glass.
Thanks for looking.
[/URL
beryllium10
Re: Zeiss 15mm f/2.8 Distagon - Some B&W
« Reply #1 on: October 28, 2017, 17:47:04 »
Aguinaldo - nice photos, with a strong flavor of black-and-white film photography (taken with a red filter and printed on No. 4 paper!).  I like the first one best - the cyclist leading into the frame and the bottom-to-top gradation from bright white sand to darkened sky are great.  For the second and third, having the horizon roughly half way up the frame risks losing the subject into the depths of the wide-angle view.  Perhaps tilting the view upward and moving closer in would have emphasized the subject of the second one, and expanded the backdrop of the dramatic sky.  Just a thought - John
« Reply #2 on: October 28, 2017, 18:42:43 »
Thank you so much for the comment John.
It surely will help me in improving my framing.
I have difficulty in expressing myself in words like you did.
« Reply #3 on: October 28, 2017, 21:13:33 »
is this the new one or the old one?... i have been told that the new is an improvement over the old one although i though the optical formula was identical.. i have noticed, at least with the old one, that this lens is generally not as sharp in the corners as the nikkor 14-24/2.8G  however, i do find it renders better in the center that the nikkor.. with that 3-d zeiss effect present.
« Reply #4 on: October 28, 2017, 21:45:07 »
This is the old, named Distagon.
The new one is named Milvus.
I really don't need to replace my Distagon with the Milvus.
I stop using the Nikkor 12-24mm because of the distortion that started to annoy me.
The difference in sharpness is insignificant to me and I prefer the 3D look.
« Reply #5 on: October 28, 2017, 23:26:23 »
ok.. i have the Distagon as well.. thx for the terminolgy..i thought they were both Distagons as that is a lens design technique.
i wil keep my copy..
nice images by the way..
« Reply #6 on: October 28, 2017, 23:35:24 »
Thank you.
I was referring to the Nikkor 14-24mm f/2.8G in my comment.
« Reply #7 on: October 28, 2017, 23:44:25 »
Thank you.
:).. i figured it was a typo
JKoerner007
« Reply #8 on: October 31, 2017, 03:56:07 »
Super images, Aguinaldo.
