Author Topic: make centre-pinch lens caps grippier  (Read 3049 times)
Lorne
  • it started with a Nikkormat
« on: October 22, 2017, 02:24:44 »
I find Nikon centre-pinch lens caps a bit slippery to grab. Applying a sliver of non-skid material (3M 7731) to the pinch points gives a much grippier surface for your thumb and finger. A short length 25 mm wide ought to last a lifetime. Just cut 5 mm slivers and apply.
Re: make centre-pinch lens caps grippier
« Reply #1 on: October 22, 2017, 08:10:57 »
That's that stuff that feels like the surface of a cinder block, right?  Excellent idea!
« Reply #2 on: October 22, 2017, 08:49:18 »
Very clever!
« Reply #3 on: October 22, 2017, 11:24:11 »
Excellent idea ! Thanks !
« Reply #4 on: October 22, 2017, 12:47:05 »
Smart solution, Lorne!
I looked for 3M 7731 at amazon.co.jp and found it costs 6,000+ JPY per foll.   :o :o :o
Looking for another solution.   :'(
jpgrahn
« Reply #5 on: October 22, 2017, 17:05:36 »
Brilliant!
I couldn't find the exact product mentioned but similar products are easy to find in hardware stores.
I went to Biltema.
Works really well.
Johan Grahn
Lorne
« Reply #6 on: October 23, 2017, 21:48:08 »
First, I have to say that I didn't come up with the idea of this, but found it on the cap of a second hand 2-035/2.8 D that I bought.
Akira, I found a local hardware shop that would sell it by the foot/metre. Also, you might try a safety supplies company.
« Reply #7 on: October 24, 2017, 00:34:03 »
Lorne, thanks!  For this particular purpose, one foot could last forever.  :D  I'll look for some possible alternatives.
Mongo
« Reply #8 on: October 24, 2017, 01:03:52 »
no denying its a good idea to improve the inside grips but , realistically, why do that when the outside grips are so, so much easier and foolproof to grip each and every time ?? Have never used the inside grips in preference to the outside ones.
CS
« Reply #9 on: October 24, 2017, 01:17:58 »
The inside grips work when there is a hood attached to the lens.
Carl
Mongo
« Reply #10 on: October 24, 2017, 01:52:13 »
Good and valid point Carl. It seems Mongo only places the hood on for a shoot and then removes it immediately after that and replaces the cap. Cannot recall a situation where the cap has had to be placed back on the lens while the hood is still on it. This seems to highlight the different styles we all have when using our equipment. Mongo mostly uses very long lenses (400mm to 600mm plus) which tend to have very large and deep hoods. For that reason , he has become used to using them the way he described above. Can understand others using them differently; especially for smaller lenses.
