Author Topic: Red-rumped Parrot  (Read 3191 times)
Lance B
Red-rumped Parrot
« on: July 07, 2015, 04:11:46 »
Red-rumped Parrot  (Psephotus haematonotus), male. Also known as Grass Parrot. A medium sized parrot of about 28cm in length mainly a seed feeding parrot, similar to the Turquoise Parrot in colouring but has a red rump on the lower back just above the tail feathers. Hard to see the red-rump unless it is flying. This guy was feeding on Dandelion Seeds.
You can just make out the red between the end tips of the folded wings:
D810 + 400 f2.8 + 1.4x TCIII, 1/1250sec, f5.6, ISO6400 handheld.
D810 + 400 f2.8, 1/400sec, f4, ISO1400 handheld
Re: Red-rumped Parrot
« Reply #1 on: July 07, 2015, 06:19:35 »
Nice Lance, love the colours of the bird.  Did you use that speed hoping to catch it departing?   With the D3S I often use even higher speeds for setting birds (meaning higher iso) because some birds to not give me a clue (Kingfishers) when they are going to launch.  The Rollers sort of hitch themselves up which gives me just enough time to change the speed quickly .  Great to have cameras that handle the iso so well  :)
Tom
bendle
« Reply #2 on: July 07, 2015, 07:03:23 »
Beautiful photos , great colours, well done.
L. S. Bendle
« Reply #3 on: July 07, 2015, 07:46:04 »
beautiful images or a beautiful bird.
Good angle.
Lance B
« Reply #4 on: July 07, 2015, 09:37:54 »
Tom
Thank you very much for your kind comments, Tom!  :)
I used the high shutter speed on the first because idiot me forgot to drop the shutter speed down from 1/focal length x 2.  >:( As I was using 560mm (400mm + 1.4x TCIII) it resulted in a shutter speed of 1/1250sec, which resulted in the high ISO as it was getting late in the day. I then removed the TC as I found I could get quite close to the bird, but I did keep the shutter speed at 1/focal length for the last two shots as the bird was walking about and chewing which meant I needed to keep it at the 1/focal length.
Lance B
« Reply #5 on: July 07, 2015, 09:38:30 »
Good angle.
Thank you very much for your lovely comments, Elsa!  :)
Lance B
« Reply #6 on: July 07, 2015, 09:39:08 »
Thank you very much for your wonderful comments, L.S. Bendle!  :)
Andrew
« Reply #7 on: July 07, 2015, 10:44:14 »
Very exotic for me.. and nice job!
Andrew Iwanowski
Lance B
« Reply #8 on: July 07, 2015, 14:29:22 »
Thank you for your lovely comment, Andrew!  :)
