Author Topic: ERA-15 f4.5 125mm takes a late walk  (Read 2024 times)
« on: September 26, 2017, 21:17:55 »
...to the park. Shot fully open on Panasonic GH4. Russian micro chip making lens. Near APO btw.
Full set is here: https://www.flickr.com/photos/kds315/albums/72157660891348788
Re: ERA-15 f4.5 125mm takes a late walk
« Reply #1 on: September 26, 2017, 21:59:35 »
Superb combination of the nice flare and sharpness of #1!  The overall rendition of the lens looks elegant: sharp but not harsh.
The background bokeh of #3 might suggest that the lens was stopped down a bit, but that is no more than a nit-pick.
« Reply #2 on: September 26, 2017, 23:46:14 »
Beautiful results again, Klaus.  This lens apparently has an iris...but did you need to add ND filtration for the shot containing the sun?
« Reply #3 on: September 26, 2017, 23:54:23 »
Yes, indeed Akira, I am quite pleased myself about that special redition, you descibed that very well! That lens is pre-stopped down, so dows not open up to a complete round circle, the aperture blades are visible at f4.5 already. I guess it was done to reach certain design parameters for that chip making process. The only little downside it has (aside from its weight).
Yes Keith, it has an adjustable iris to f32. It was late in the evening just before sunset, and having an electronic shutter to 1/16000 sec, was enough to handle the sunlight, also since it is a not too fast lens at f4.5 [I do use ND filters, rear mounted within the adapter, on fast projection lenses though...]
