Author Topic: Difference between APO Lanthar 125mm 2,5 in SLi and SLii  (Read 2309 times)
Gigas
« on: September 18, 2017, 10:32:28 »
What is the difference between the two SLi and SLii? Is there a Nikon mount on both?
Re: Difference between APO Lanthar 125mm 2,5 in SLi and SLii
« Reply #1 on: September 18, 2017, 11:04:14 »
There is no SLii version as far as I know, I have never seen one,,,
The later versions of the other focal lengths have different mechanical internals and not the 'universal' interchangeable mount
Gigas
« Reply #2 on: September 18, 2017, 11:22:16 »
Ok, and thank you. I will hunt also for a lens like that with a Nikon mount!
« Reply #3 on: September 18, 2017, 13:08:35 »
If I remember correctly, the Nikon F mount SLII lenses had CPUs.  Apo-Lanther 125/2.5 had been discontinued before the lineup was updated to SLII.
« Reply #4 on: September 18, 2017, 15:05:06 »
This is a pretty good site for Voigtlander lenses:
https://www.cameraquest.com/Voigt_SL2.htm
No idea about his prices but he has been recommended to me by several folk I trust .  The site has a lot of info.
Tom
« Reply #5 on: September 19, 2017, 00:32:38 »
Tom
About the highest prices you may find on the net...but very reliable.
« Reply #6 on: September 19, 2017, 07:15:33 »
Dr Klaus, that appears to be true on prices and also they have eliminated some of the more detailed info on older lenses.  I use Robert White (UK) although he is no longer with us and the ownership has changed.  I normally get some good prices from them and have pretty consistent contact with UK if gear needs repair (pretty tough and expensive here in India for Leica and Voigt).
