Author Topic: Medical Nikkor 120mm f4  (Read 19803 times)
Re: Medical Nikkor 120mm f4
« Reply #45 on: September 03, 2021, 04:30:16 »
Just a quick link to a manual...
https://cdn-10.nikon-cdn.com/pdf/manuals/archive/Medical-Nikkor%20120mm%20f-4%20IF.pdf
I think this is the search I used and while look through the hits I found a bunch of Nikkor lenses manuals...
https://duckduckgo.com/?q=Nikon+F+lens+and+camera+bayonet+nomenclature+&t=hx&va=g&ia=web
Many from Nkion Canada
Macro_Cosmos
    • Flickr
« Reply #46 on: April 29, 2024, 15:53:29 »
Sorry for digging this thread up.
May someone share the repair manual with me?  Or explain how the aperture and focus linkage can be removed?  I was finally able to purchase one of these and to my surprise, I cannot find any information online regarding the modification.  It sounds simple but from what I have read so far, it might be quite difficult.
I would like to assume that the optics require no work.
Blog: Diatoms Australia
« Reply #47 on: April 29, 2024, 16:27:23 »
Erik should know. Shoot him a PM. Do note you'll need a CPU in the lens to fully exploit the advantages of removing the aperture/flash linkage.
Macro_Cosmos
    • Flickr
« Reply #48 on: April 29, 2024, 17:14:02 »
Thanks a lot Birna!  I will DM Erik later.
I plan on only using the lens wide open where it should perform the best.  I might add the chip too as I think I have enough skills now to do such a modification.
The other plan is to install an LED ring light powered by a USB power bank to act as some sort of manual focus assist when it gets dark.  I am personally not a fan of the flat ring light look.
« Reply #49 on: April 29, 2024, 20:39:29 »
Once you can set the aperture at will, there is no need to use the built-in ring flash at all.
Looking quickly through my archive for images taken with the 120 Medical, I noticed at lot of them were acquired at aperture settings f/11-f/22. Chasing butterflies however were with f/4-f/5.6. So it all dependens on the purpose and motif of the picture.
Macro_Cosmos
    • Flickr
« Reply #50 on: April 30, 2024, 04:17:34 »
Chances are, mine will be used for relatively still subjects such as flowers and slow critters, I will likely do bursts and focus stack.  I have sent Erik a message, thanks!
There were several opportunities to pick this lens up at less than $50, ones that were infested with mushrooms.  I regret it now, I should have bought one to do a trial on before taking the surgery on my nice boxed copy.
« Reply #51 on: April 30, 2024, 08:32:08 »
I would not say it is quick fix to remove and change/fix the linkage. You need to disassemble the rear quite far to get to it and the set it at smallest aperture to let the camera control it via the stop down leaver, as Birna mention this will only work if an appropriate CPU is installed. If not, the aperture will not stop down correctly,,,
Yes, you can disable the aperture and aperture lever,,, all manual,,, not recommended.
Macro_Cosmos
    • Flickr
« Reply #52 on: May 16, 2024, 16:57:39 »
The lens arrived.  It was in such good condition, I would rather leave it without modifications.  I will try and get another unit that I do not mind messing with.
At first glance, the aperture is limited corresponding to each magnification.  However, at higher settings, it can be opened up.  It cannot be closed beyond the fixed settings at low magnifications.  This makes a lot more sense to me now, I was confused about the necessity of contacts to control the aperture, as I thought it allowed no adjustments and had no prong to engage the iris.
All I have to do is to find a ring which engages the aperture, maybe an AI/AIS-M42 ring and then adapt it back to F-mount, get some extension tubes to achieve the correct magnifications.  I only plan on using the lens at higher magnifications anyway, so the handicap does not affect me.
There was even a printed warranty certificate.
The warranty is only valid in Japan, oh no!  My warranty.   ::)
Macro_Cosmos
    • Flickr
« Reply #53 on: May 16, 2024, 17:22:51 »
Looks like the BR-4 ring does exactly what I want it to do, bye spring.
The crude adaptation is now complete.  The aperture prong of the lens itself is spring loaded too, I can just use a piece of tape to stop it from closing.
« Reply #54 on: May 17, 2024, 06:54:05 »
As long as the lens delivers the images you want, why not?
However, adding extension to that lens to set it to a given magnification might not be the optimum approach for quality. I'm curious about the results.
bressong
  • a nikon user
« Reply #55 on: May 19, 2024, 05:10:52 »
wow, how it can be new in this way 8)
« Reply #56 on: May 21, 2024, 12:38:14 »
Sure lives up to the most often misused condition rating: Mint  :o :o :o
Looks like NOS, New Old Stock is appropriate here  8)
Macro_Cosmos
    • Flickr
« Reply #57 on: June 17, 2024, 07:24:12 »
Nope, no extension at all!
I used an F-mount (female) and then a slight extension to the Z-mount to achieve the same overall length as the FTZ adaptor.
I am waiting to get another one to mess with, this one will be boxed back up and sold because I do not want to ruin it.  Someone might be able to appreciate it more than I do.
There are some reports that adding extension to achieve a certain magnification within the lenses' design yields better images than properly setting it, and some to the contrary.  Trial and error...!
Macro_Cosmos
    • Flickr
« Reply #58 on: June 17, 2024, 07:27:25 »
This is what the crude adaptation looks like.
The lens is front heavy, I will have to 3D print a lens collar.  Handholding this is a nightmare when I have to claw that aperture prong.  Hopefully, I can get another one soon to mess around with.
Macro_Cosmos
    • Flickr
« Reply #59 on: July 18, 2024, 02:18:35 »
This is now way out of my comfort zone.  I can see the aperture is limited mechanically by an arced ring, but it is attached deep down with screws facing downward.  How do I even reach that spot?  I would have simply cut it but the limited working space makes this risky, if not impossible.
Any direction is appreciated!
Thanks.
