Author Topic: Total Solar Eclipse, Oregon, 10:17am 8-21-2017  (Read 5949 times)
Kuri
« on: August 22, 2017, 05:09:13 »
Total Solar Eclipse, William L. Finley National Wildlife Reserve, Oregon, 10:17am 8-21-2017.
The roosters started crowing, Venus was visible overhead, and the photo just doesn't do it justice.
These were done with a D7000 UVIR conversion, and the Nikon 200-500mm lens + 1.4 teleconverter.
The before/after totality pics were done with a Baader H-Alpha (35nm band width version) stacked with a Baader AstroSolar 3.8 OD filter in the front.
DANGER: 3.5 OD can NOT be used to view the sun with your eyes, you need to use AstroSolar 5.0 OD to view the sun with your eyes. Be VERY careful which you use for what.
The totality shot is not filtered, it is a 'full spectrum shot'.
Re: Total Solar Eclipse, Oregon, 10:17am 8-21-2017
« Reply #1 on: August 22, 2017, 05:23:24 »
Beautiful corona/prominence shot!  I also like the partially eclipsed sun through the H-Alpha filter: the ripples on the surface are well seen.
Thanks for sharing, and I would also say, congratulations!
Fanie
« Reply #2 on: August 22, 2017, 06:19:37 »
Excellent photos, thanks for posting.
Fanie du Plessis
Pretoria,  South Africa
Ann
« Reply #3 on: August 22, 2017, 07:35:25 »
Spectacular results.
You certainly took full advantage of being in the right place at the right time.
Bill Mellen
« Reply #4 on: August 22, 2017, 07:39:34 »
Beautifully done!
« Reply #5 on: August 22, 2017, 08:03:27 »
sweet.... excellent results
« Reply #6 on: August 22, 2017, 09:22:38 »
Beautiful shapes and colours.
« Reply #7 on: August 22, 2017, 09:24:27 »
Kuri, these are fantastic! You should be proud of them!
« Reply #8 on: August 22, 2017, 09:31:08 »
Great pictures ! Total unknown territory for me. Maybe one day ...
David Paterson
« Reply #9 on: August 22, 2017, 11:30:08 »
Spectacular, and very professionally done.
« Reply #10 on: August 22, 2017, 11:43:39 »
You certainly used your allotted 57 seconds well :D good planning of how to deal with a spectacular event, and the necessary bit of luck with weather too. Kudos.
  • Fairbanks, Alaska
« Reply #11 on: August 22, 2017, 11:56:34 »
Very well done, thanks for posting!
« Reply #12 on: August 22, 2017, 13:34:28 »
Phantastic footage in a well through through setup. It was really worth the fuzz!
« Reply #13 on: August 22, 2017, 19:23:42 »
Awesome ! Thanks for sharing your fantastic results !
simato73
« Reply #14 on: August 22, 2017, 21:07:48 »
I am totally floored.
Simone Tomasi
