Author Topic: The Clean-Up Crew  (Read 1834 times)
ArthurDent
The Clean-Up Crew
« on: August 12, 2017, 00:18:48 »
Comments and criticisms much appreciated.
Re: The Clean-Up Crew
« Reply #1 on: August 13, 2017, 13:41:06 »
Great detail on the face and interesting angle.
Pity about the blown highlights.
« Reply #2 on: August 13, 2017, 19:25:34 »
Billy was a bad man and carried a big gun.
He was always after lawmen and kept them on the run.
One day he met a bad man who was a whole lot badder.
Now he's dead and gone and we ain't none the sadder.
--The Boot Hill Boys
Sorry the 😈 made me do it.
I think the blow areas could be pull in if there is a RAW file to work with.
ArthurDent
« Reply #3 on: August 13, 2017, 20:23:43 »
I don't think there are any, but I'll check again as soon as I get done cataloging my photos. There was one small black area at the juncture of the top and bottom beaks, but I don't think there were any blown out areas.
Where do you think you see it?  On my monitor the shoulder area is pretty light, but I can still see detail throughout.
« Reply #4 on: August 13, 2017, 21:38:44 »
Certain areas of the brightest feathers at lower center are detail-less on my laptop.  But detail-less isn't necessarily the same as blown out.  I'll look later on my better monitor.
Any hints about the species name of this magnificent organism?
ArthurDent
« Reply #5 on: August 13, 2017, 22:15:59 »
Since I got my copy of Lightroom 6, I set the whites and blacks by using a shift double click on white and black, which pretty much (although not completely in all cases) eliminates clipping, so I'd be surprised if there are a significant number of blown pixels in the image.
I think the bird was African, but I can't dredge up a name. Maybe Elsa or one of the other African residents could tell us.
« Reply #6 on: August 13, 2017, 23:58:36 »
I don't think anything important is blown, but the parts of the image might benefit from an exposure reduction in LR.
« Reply #7 on: August 14, 2017, 08:00:14 »
The feathers at the lower edge of the frame are push to high on the scale. A normal curve will compress the contrast up there. Also the eye can't differentiate the tones well there. That area may not be blown out proper but it's too hot.
ArthurDent
« Reply #8 on: August 14, 2017, 14:06:27 »
Thank you for your comment, you have a good eye.
« Reply #9 on: August 15, 2017, 04:01:20 »
Upon viewing on a large, better monitor I see that the area under discussion is slightly out of the field of focus, so not much detail is ever going to show.  It's fine the way it is.
ArthurDent
« Reply #10 on: August 15, 2017, 14:37:14 »
You have a good eye as well.
Unfortunately, I seem to have lost the metadata for that shot. But I've got several other shots taken at the same time which may shed some light on it. I believe the shot was at f/2.8, but I'm not sure about the other parameters. When I get done cataloging my photos in Lightroom, a task comparable to sweeping out the Aegean stables, I'll see if the metadata from the other shots transferred. I'm probably a day or two away from that happening, as I am trying to winnow as I organize, I've been working on it for 4-5 days in the early mornings and after work.
ArthurDent
« Reply #11 on: August 16, 2017, 13:43:09 »
Here is an update. What do you think?
Bill Mellen
« Reply #12 on: August 16, 2017, 17:34:21 »
Clean-up crew reporting for duty!
I like #1 better, clipped highlights and all.  It has more "punch" to me.  Maybe something in between.
