Author Topic: Found  (Read 3676 times)
Grahame Hamblin
Found
« on: August 01, 2017, 00:11:33 »
Found in a box unused in garage from years ago a 2x macro vivitar. put it on the 300f4  image full frame un cropped is it worth carrying on with did take a few others rubbish but i think that was me
Grahame Hamblin
Re: Found
« Reply #1 on: August 01, 2017, 00:40:34 »
Should have added manual focus hand held auto does not work
Grahame
Re: Found
« Reply #2 on: August 01, 2017, 02:01:24 »
Would this be the macro focusing teleconverter, that has a 2X converter and a focusing helicoid?
Shoot a few more test shots with the camera locked down or on a tripod.  Then do a few w/o the converter on the same setup. Then you'll see what the converter does to the image quality.
Oskar O
Re: Found
« Reply #3 on: August 01, 2017, 15:39:57 »
Those make for excellent extension tubes when the optics are removed.
Grahame Hamblin
Re: Found
« Reply #4 on: August 01, 2017, 21:22:57 »
yes it is helicoid will test on lockdown.
had not thought of removing glass have done this to old zoom lens works great
Grahame
Steven Paulsen
  • Cumpulsive Tinkerer
Re: Found
« Reply #5 on: August 03, 2017, 19:58:49 »
I'd test your converter on a few other lenses B4 removing the glass. Depending on which/what version you have.....(I've found that many old vivitar products, are or can be,.......really great performers.)
Matthew Currie
Re: Found
« Reply #6 on: August 07, 2017, 20:39:00 »
It seems to depend on various factors. Some converters are most at home with some specific lenses.  I had a pre-AI Vivitar 2x converter that was never very good, but I had a Vivitar 2x AI converter that mated to my old 80-200 F4 with surprising sharpness at the long end, though not so well with anything else.  I'd definitely try it in a few places just to check.  There may be a sweet combination.
Grahame Hamblin
Re: Found
« Reply #7 on: August 07, 2017, 21:45:58 »
Thanks Matthew it is in my to do box.
Grahame
Grahame Hamblin
Re: Found
« Reply #8 on: August 12, 2017, 02:16:32 »
Had a bit of a play not bad  but not perfect would love comments
300mm pf plus 2 times macro (old) 25sec no idea on aperture 64 iso
Fucia stamen
Grahame Hamblin
Re: Found
« Reply #9 on: August 12, 2017, 03:43:26 »
This time using the zeiss 135 apo f2
Re: Found
« Reply #10 on: August 12, 2017, 05:38:01 »
The second one (w/ the 135) shows a useable quality.  The first one is either out of focus, or the 300PF is not a good candidate for this converter.
Grahame Hamblin
Re: Found
« Reply #11 on: August 12, 2017, 09:14:59 »
Thank you Pluton will do some more testing but agree the 135 Will try the 70-200 The hardest part is focus.but grew up with that
Grahme
Re: Found
« Reply #12 on: August 12, 2017, 21:38:21 »
The first one looks more in focus towards the back of the stamen, if it had been focused a shade closer it would look sharper.
