Author Topic: Best way to greater magnification for macro work  (Read 11313 times)
Re: Best way to greater magnification for macro work
« Reply #45 on: August 11, 2017, 23:08:51 »
I also heard that the RAYNOX is a cemeted 3-element design, which should explain why it is so praised!!
« Reply #47 on: August 12, 2017, 00:17:11 »
Klaus, according to the website of Raynox, both DCR-150 and -250 are of 2G3E design.  So, two elements are cemented.
Bob, the additional info is interesting.  Thanks!
« Reply #48 on: August 12, 2017, 00:45:42 »
According to Kenko, AC Closeup lenses No.2 (500mm) and No.3 (330mm) can be combined to make a No.5 of 2G4E design.  In order to calculate the exact combined focal length, you need to know the distances between the lenses screwed together, which is not given on their website.  I don't know whether their calculation is exact or rounded.
« Reply #49 on: August 12, 2017, 00:50:35 »
using the thin lens formula it works out to be almost 200mm  1/f = 1/f1 + 1/f2
the only missing term is subtracted -d/f1*f2  where d = distance between them --   this term is very small
