Author Topic: Flowers under harsh lightings  (Read 1076 times)
« on: July 28, 2017, 13:04:53 »
Shot with D750 and Ai 200/4.0.  Apparently the lens is prone to flare.  The post-processing for these images were tricky.
ArthurDent
Re: Flowers under harsh lightings
« Reply #1 on: July 28, 2017, 14:33:58 »
Very nice images. What software do you use for post processing?
« Reply #2 on: July 28, 2017, 14:45:07 »
Thanks, Arthur!
I use CC2017.  The first image looked quite hazy possibly caused by the internal flare of the lens.  So, I used the "dehaze" slider in ACR in addition to the usual ones.
The flowers in the second image were very dark in the original RAW, and I needed to raise the shadow slider quite a bit.  I think I should have used the Active D-light function in the camera.
Randy Stout
« Reply #3 on: July 28, 2017, 17:03:44 »
Akira:
I like the colors and the cloudy sky, def. more sense of depth.
A bit more exposure compensation for the flowers might have helped with the luminosity balance between them and sky.
The dehaze filter is an interesting one.  I play with it occ. Sometimes works a treat, other times, not so much.
Cheers
Randy
« Reply #4 on: July 28, 2017, 18:09:52 »
Randy, thanks for the comment and the suggestion.
Indeed a bit more brightning of the flowers might have helped.  But I feared if the image looks more like HDR which is not really my taste...
I agree that the dehaze slider is sometimes more functional than its name indicates.  It is also handy when I want to reduce the smoke of the firework shots.
