Author Topic: Some IR snaps wth 8mm fisheye (old one)  (Read 1269 times)
« on: June 09, 2017, 21:03:06 »
Nikon D800E RG830 ,Nikkor 8mm f/2.8 Fisheye Ai-S
1/80s f/8.0 at 8.0mm iso200
Nikon D800E RG830,Nikkor 8mm f/2.8 Fisheye Ai-S
1/100s f/8.0 at 8.0mm iso200
1/200s f/8.0 at 8.0mm iso200
Re: Some IR snaps wth 8mm fisheye (old one)
« Reply #1 on: June 09, 2017, 21:18:07 »
Very nice.
I like #3 best.
One chalenge while using this lens is, when placing the horizon in the middle to avoid the curve, is to give the impression that it is not tilted.
« Reply #2 on: June 09, 2017, 21:40:37 »
Good point... Another is to avoid flare from the sun.. not so easy to just tilt the lens or hide behind a tree.
« Reply #3 on: June 09, 2017, 22:21:52 »
What is RG830?
How did you get the IR effect? Converted camera?
Thanks.
« Reply #4 on: June 09, 2017, 23:22:08 »
What is RG830?
Thanks.
yes.. the UV/IR cut filter that was stock on the sensor was replaced with an 830nm long pass filter.  RG830 (Red/Green) is a Schott Glass designation for the filter.
« Reply #5 on: June 10, 2017, 00:56:21 »
Thank you.
« Reply #6 on: June 10, 2017, 00:58:19 »
They look familiar to me, but I've never gotten bored.
« Reply #7 on: June 10, 2017, 05:44:43 »
i need to find some better spots.
