Author Topic: D500 battery drain persists  (Read 14265 times)
Re: D500 battery drain persists
« Reply #15 on: December 07, 2017, 18:01:37 »
Have you tried to reset all, it is in the camera setup menu.
It will reset all but language, time and time zone.
If this doesn’t help I guess there’s a fault with the camera  :(
I reset the settings when I purchased the body a couple of days ago - and then set it up as I wanted it
« Reply #16 on: December 07, 2017, 18:26:17 »
excuse my ignorance - how does  sleep mode display? I have display mode set to 4 secs - which means the light goes off after 4 seconds but the info is still on the little screen showing which mode it is in etc
Does it show shutter speed and aperture? If yes there is a fault
« Reply #17 on: December 07, 2017, 19:01:01 »
No it doesnt show shutterspeed or Aperture
I have taken battery out now - charging it and see how it performs tomorrow :( I am leaving on a safari in a week's time, so I hope I can sort this out sooner rather than later - thanks for trying to help
« Reply #18 on: December 07, 2017, 19:07:46 »
Perhaps a thought to ponder - I have (finally!) switched to using the BBF which I have never used before - so I may be holding that down far more than I should - its a very new way of shooting for me.
« Reply #19 on: December 07, 2017, 19:28:44 »
When the sleep mode is activated, the display should look the same as when the camera is switched off (it only shows the remaining frames and the recognized cards, if I remember correctly).
What is BBF?  Best boy friend?!   :o :o :o
« Reply #20 on: December 07, 2017, 19:32:52 »
Ah - okey the D500 doesnt have a sleep mode - just "stand by" (and you choose for how long - mine set on shortest - 4 secs)
Best Boy Friend needed to buy me a D5 ya
Back Button Focus ;D
« Reply #21 on: December 07, 2017, 19:38:56 »
D500 doesn't have a sleep mode?  Really?  Again, "sleep mode" may not be the correct term for the menu item.  That being said, if your D500 drains the Li-ion20 battery that fast, something should be going wrong.  D500 is supposed to be more power efficient than the already efficient D750.
And, yes, your best boy friend has to be rich and young.  :D
« Reply #22 on: December 07, 2017, 19:43:40 »
Stand by mode is supposed to take care of the sleeping bit.
I have now found a lot of complaints about the battery drain via my friend Googling. But no solution that I could see.
Akira - you forgot the rest - nice young rich virile and must cook. Until then - I am stuck with Nikon as a lover haha. It must be a male body giving me all this trouble  ;D ;D
Having said that - it does perform...
basker
« Reply #23 on: December 07, 2017, 20:20:37 »
You make an absolutely charming couple though, and the birds are beautiful.
Sam McMillan
« Reply #24 on: December 07, 2017, 20:34:12 »
Thank you Basker - I am not contemplating divorce yet. Murder - perhaps
« Reply #25 on: December 07, 2017, 20:53:55 »
The first image is already familiar to me on Facebook.  :)
Hope your D500 is die-hard.  :D
« Reply #26 on: December 07, 2017, 21:03:06 »
 ;D ;D ;D ;D ;D
« Reply #27 on: December 08, 2017, 01:57:35 »
If a recent Nikon is set to AF-C and the lens has VR and VR is switched on and the AF-ON button is pressed then the CPU,  AF-C and VR will all be active and draining the battery (nice run on sentence, yes?). I don't see this as a reason not to use the AF-ON button, AF-C and VR but rather a reason to carry extra batteries. I switch my batteries out when about 50% depleted.
The camera may still have a fault but the features mentioned above all shorten battery life.
« Reply #28 on: December 08, 2017, 04:12:12 »
Elsa, is this the in-camera battery, or the battery in the grip? Just wondering if a bad connection between grip and body could cause something like this?
Also, there are a couple of other settings in the Setup menu which I would make sure are turned off, just in case.
Such as making sure Bluetooth is not set to "send while off" and Eye-fi is set to disable.
I believe that airplane mode should take care of these, but just in case?
« Reply #29 on: December 08, 2017, 08:26:24 »
Not using VR
battery drains when in standby mode I not being used
Using battery in body - grip taken off
Bluetooth/wi fi is off when you enable Airplane mode - double checked
