Author Topic: Close-ups from the garden  (Read 1436 times)
Andrew
« on: June 01, 2017, 10:02:55 »
D500, 200-500/5.6+TC14III, monopod with gimbal, VR on, windy(almost like in Michigan...)
Andrew Iwanowski
Re: Close-ups from the garden
« Reply #1 on: June 01, 2017, 13:10:46 »
Andrew - I dont understand the artifacts in the background - what size are your images posted at? sorry I just saw now. They appear very unsharp - are you able to post bigger? say 2000 pix long side? At at least quality 10?
Andrew
« Reply #2 on: June 01, 2017, 20:02:59 »
Artifacts-maybe VR on, maybe not enough of DOF, was used f/8-this mean full aperture.
Any way that was exercise, just to gain if this kind of set(camera/lens) will produce decent results.
I did re-processed three pix...
And thank you for the comment!
Andrew Iwanowski
« Reply #3 on: June 02, 2017, 15:50:50 »
Wow Andrew!
Andrew
« Reply #4 on: June 02, 2017, 19:54:51 »
This mean you like it?????
Andrew Iwanowski
« Reply #5 on: June 03, 2017, 09:06:36 »
Yes, most certainly!
I do see quite heavy posterization in the files, probably from jpeg compression. Perhaps there is a way to compress them less, to even better appreciate the result.
Andrew
« Reply #6 on: June 03, 2017, 09:50:10 »
Well, I will started from the scratch-process RAWs again...
Andrew Iwanowski
« Reply #7 on: June 03, 2017, 09:56:19 »
Whatever you did, don't compress files this heavily ... A single file on NG can be up to approx. 2.5 MB, these are just a few hundred KB.
