Author Topic: The Most Useful ISO, etc. Graph  (Read 7927 times)
bclaff
    • Photons to Photos
Re: The Most Useful ISO, etc. Graph
« Reply #15 on: May 29, 2017, 18:57:42 »
Size of a print does relate to resolution.  A photo with lower resolution, whether film or digital, can be enlarged less on a print or monitor before it loses apparent sharpness.  But this is a separate matter from dynamic range.
The apparent dynamic range is affected by the overall viewing angle in a way that's equivalent to thinking about the Circle of Confusion (CoC).
Viewed from sufficiently far away (very small viewing angle) all photographs have an apparent dynamic range of 1.
Naturally print size affects viewing angle too.
« Reply #16 on: May 29, 2017, 21:10:55 »
That's very observant. The data for all cameras was updated and most rose a little bit.
Also, I do update results as I get better data. The D750 is on my list to request a new batch of files. Normally these curves are smoother.If you're referring to the second section of PhotonsToPhotos with DxOMark derived data, that is correct.
Since DxOMark never retests a camera curves there would never change.
Bclafff, so, you are the owner of the website.  Thanks for the clarification!  Glad to know the reason for the discrepancy.
bclaff
    • Photons to Photos
« Reply #17 on: May 29, 2017, 21:30:31 »
Bclaff, so, you are the owner of the website.
Sometime I think it owns me.  :D
No problem. Always striving to keep people properly informed.
« Reply #18 on: May 29, 2017, 23:51:24 »
FWIW, Phase One IQ3 tops the crowd.
http://www.photonstophotos.net/Charts/PDR.htm#FujiFilm%20GFX%2050S,Hasselblad%20X1D-50c,Nikon%20D750,Nikon%20D810,Phase%20One%20IQ3%20100MP
The IQ3 is an announced product, not a shipped one. Maker says they will deliver in August. And the price is VERY SIGNIFICANT
bclaff
    • Photons to Photos
« Reply #19 on: May 30, 2017, 00:08:34 »
Shipping since early 2016 as far as I can see. PhaseOne
Perhaps they are current out of stock and you couldn't get one until August.
« Reply #20 on: May 30, 2017, 14:05:24 »
May be you are referring to the IQ3 100MP Achromatic back (B/W) which is new ?
https://www.phaseone.com/en/IQ3-100MP-Achromatic.aspx
« Reply #21 on: May 30, 2017, 17:49:25 »
MFloyd. Yes. That is the one. I did not know they were two different versions. The new one sells for 45.000€ I understand???
« Reply #22 on: May 30, 2017, 17:55:50 »
I learn the Color version is cheaper.
Just short of 40.000€
Bill De Jager
« Reply #23 on: June 05, 2017, 04:20:19 »
I am just starting to learn all about digital photography and a bit of the science behind the sensors. When plugging my two recent and first digital purchases (Nikon 1V1 and D2h) into the graph, the results are rather abysmal.
Comparative results for very small sensors such the CX-format sensor as on the V1 are always going to look bad.  But compare the V1 performance to the ideal CX performance for dynamic range and it doesn't look anywhere near as bad.  The choice to get a small-sensor camera is a willful trade-off of absolute performance for small size and portability that many photographers make, often for a second camera.  It's a choice of tool(s) for a given set of situations.  As the saying goes, the best camera is the one that's actually with you when you see an opportunity for a good photo.
However, some camera models do a better job than others of maintaining a small body size for a given sensor size.  The Sony 6xxx cameras are remarkably small for APS-C sensor cameras, though they have a far smaller native lens set than Canon or Nikon crop-sensor DSLRs.  Still, dynamic range performance is only one consideration among many others such as sensor noise, autofocus and manual focus capabilities, ergonomics, available lens sets, etc.
Finally, progress on sensor performance has been somewhat uneven over time.  For instance, compare the D70, D80, and D90 and note the sudden large jump in dynamic range performance when the D90 was introduced.  When considering upgrading to a better used camera, it's useful to consider such jumps in performance as potentially good entry points.
Agreed then that there is a some sort of relationship between print size and dynamic range.  But how significant is this factor when viewing prints of different sizes from fairly close? For instance, I don't think you'll lose half the dynamic range by reducing print size by 50% linearly, even though you'll definitely lose half the linear resolution if the larger print was sharp.
