Author Topic: West Parish Chapel, Andover, MA - RG830  (Read 1580 times)
« on: May 28, 2017, 20:45:13 »
Nikon D800E RG830 ,Nikkor AF-S 14-24mm f/2.8G ED
1/160s f/8.0 at 14.0mm iso200
Re: West Parish Chapel, Andover, MA - RG830
« Reply #1 on: May 28, 2017, 22:43:43 »
Great image Bob. Good range of tones and I like the framing.
And (slightly off topic), one that Blue Oyster Cult might have used back in the 1970's
« Reply #2 on: May 28, 2017, 23:28:20 »
Great image, really like how the trees frame the chapel
« Reply #3 on: May 29, 2017, 08:41:45 »
Great image Bob - as already noted.
If I read your technical detail correctly you are using an 830nm filter and a Nikon 800E.  From your exposure details I am guessing that the camera has been modified.  Correct?  If so, did you encounter any issues with IR components as used for AF by the camera itself?  Some Nikon DSLRs had such issues - IIRC some of the D7*** DX cameras.
Thanks in advance.
« Reply #4 on: May 29, 2017, 11:11:52 »
Yes.. the camera was modified internally. The UV/IR cut filter was removed and replaced with an RG830 long pass directly on the sensor. I do not understand the rest of your question?
« Reply #5 on: May 29, 2017, 12:12:17 »
Nikon D800E RG830,Nikkor 8mm f/2.8 Fisheye Ai-S
1/200s f/8.0 at 8.0mm iso200
