Author Topic: Nikon 35-70mm 2.8D Repair  (Read 4534 times)
mysh
« on: May 25, 2017, 01:39:49 »
I wanted to check and see if anyone here has ever taken apart the Nikon 35-70mm 2.8D push pull.  I have taken apart quite a few manual focus nikon lenses but I try to stay away from AF lenses.
The only reason I am thinking of doing it is because the fix I want to do could be very easy. I have 2 of these lenses. One of them has is near mint but has a chip in the front element, and the other is beat up but has a perfect front element. I just want to swap the front glass.
Looking at it it seems like it might be as simple as taking off one of the black rings around the glass. I have the proper tools to do this but wanted to check and see if anyone has ever messed with it. The last time I took a part off a AF lens things immediately started flying out of the lens.
Steven Simpkins
    • Studio Graphics Photography
Re: Nikon 35-70mm 2.8D Repair
« Reply #1 on: May 30, 2017, 02:55:44 »
The front element is easy as long as you have a spanner wrench. Also the ring has a thread locker on it. I used either isopropyl or some other solvent to loosen (PB Blaster - tiny amount) and I can't remember which worked. Once the ring is spun out, the front element is easily removed.
Are you keeping the beater?
« Reply #2 on: May 30, 2017, 10:46:46 »
maybe I should make a repair article for this one of these days  :o :o :o
« Reply #3 on: May 30, 2017, 10:50:59 »
mysh
« Reply #5 on: June 11, 2017, 09:19:55 »
thanks everyone for the comments. If I understand correctly I just need to use my spanner wrench to unscrew the smaller front ring to remove the front element.
The beater has issues. Its more for parts than a working version. Not sure what the issue is but it would need work. I would get rid of it if someone wanted to mess with the lens.
« Reply #6 on: June 11, 2017, 09:33:57 »
did you check the image quality? there are times when a swap will not work  :o :o :o
Wannabebetter
« Reply #7 on: July 09, 2017, 09:57:26 »
I would appreciate very much an opportunity "to mess" with that venerable lens.
