Author Topic: Another from the London Lens Show  (Read 3080 times)
Mike G
« on: May 07, 2017, 08:12:46 »
This is the Canon stall, which seemed to be hiding behind this assorted shrubbery!
Mike G
Re: Another from the London Lens Show
« Reply #1 on: May 07, 2017, 08:18:16 »
Another exhibit, this time a Zeiss lens bisected, the rep told me that the cost of cutting an actual lens apparently is more the the cost of the lens itself, which is about £3000!
« Reply #2 on: May 07, 2017, 08:28:28 »
Strangely I've never seen the other halves of such cut models!
« Reply #3 on: May 07, 2017, 08:39:53 »
They get two halves - just glue them together later and sell as "refurbished" :D
By the way, I have one or two "half-lenses" myself. Actually, you can make a photo with them if the open part is covered with a black material.
« Reply #4 on: May 07, 2017, 08:51:53 »
LOL!
I always thought that the other halves were sacrificed to make perfectly clean halves...
Mike G
« Reply #5 on: May 07, 2017, 08:55:03 »
I did ask if you turn it over will all the bits fall out and was told yes so the components are glued in place and the diaphragm unit is removed. Apparently there is a very high risk of the lens glass shattering when this is done!
What I find interesting is the intricacy of the construction!
simato73
« Reply #6 on: May 07, 2017, 09:42:48 »
Obviously this is not your standard, crappy consumer lens.  :)
Simone Tomasi
« Reply #7 on: May 07, 2017, 12:38:48 »
Simone, it looks like one of the Compact Prime CP.2 cine lenses.  Probably Distagon 25/2.8.
Mike G
« Reply #8 on: May 07, 2017, 13:56:42 »
Akira, maybe one of these?
« Reply #9 on: May 07, 2017, 15:25:47 »
Amazing construction , I see what I presume are helicoid threads on many places, certainly not a lens to be serviced by a beginner
Mike G
« Reply #10 on: May 07, 2017, 16:32:33 »
I think Akira may be right in thinking that they are cine lenses!
« Reply #11 on: May 07, 2017, 19:00:19 »
Akira, maybe one of theses?
Yes, I think so.
Yesterday I saw a real CP.2 (50mm/T2.1).  It was beautifully made and it had a Nikon mount attached.  But it was too big (100mm filter thread) and too expensive (360,000+ JPY used).
Bill De Jager
« Reply #12 on: May 07, 2017, 21:42:32 »
I would assume they'd sacrifice a defective unit, for instance one that was seriously but not visibly decentered.  Zeiss lenses cost more in part due to better quality control, and that in turn means there must some rejects.
« Reply #13 on: May 08, 2017, 00:02:52 »
They end up at Westlicht camera auctions!! :-)
