Author Topic: Fooling around with a Noct-Nikkor  (Read 14292 times)
Re: Fooling around with a Noct-Nikkor
« Reply #45 on: April 25, 2017, 07:25:11 »
Mine also has lower contrast at f/1.2-f/1.4 compared with itself at smaller apertures (big jump at f/2). Wide open however, it still beats the other fast lenses I have around.
More to come but, for the time being, days are full and nights too short.
« Reply #46 on: May 05, 2017, 17:23:50 »
Daytime, nevertheless f/1.2
« Reply #47 on: May 10, 2017, 05:14:34 »
All relatively close focussed and wide open (but the second one, f/2.8). Firenze, yesterday.
« Reply #48 on: May 21, 2017, 22:46:07 »
Another one wide open. Focus slightly missed (wrong eye), but it was actually much darker than it seems here.
JJChan
  • JJ Chan
« Reply #49 on: May 22, 2017, 16:38:27 »
Nice work Airy
Can I ask how you tested the focus shifting? Mine doesn't seem to shift but I need to replicate your setup to make sure we are comparing the same thing
JJ
« Reply #50 on: May 22, 2017, 22:15:16 »
I've used the Spyder Lenscal target (with the oblique ruler) at about 1.5m, Noct mounted on D800, LV focussing using the Zacuto eyepiece.
« Reply #51 on: May 22, 2017, 22:58:07 »
According to my experience, focusing a Noct with any accuracy using this setup is next to impossible. Try the Df or similar to learn if you can improved and more consistent results.
« Reply #52 on: May 22, 2017, 23:11:32 »
...I forgot to mention : tripod...
jhinkey
« Reply #53 on: May 22, 2017, 23:17:31 »
Or perhaps an A7RII :)
« Reply #54 on: May 22, 2017, 23:39:01 »
By all means - if one has better luck than I did with those models ...
