Author Topic: Practical advice on Nikkor 55 1.2 SC Auto  (Read 4514 times)
Re: Practical advice on Nikkor 55 1.2 SC Auto
« Reply #15 on: April 01, 2017, 16:23:07 »
... On another forum in another life people were saying that entering the correct maximum aperture in the non-CPU data was not important hence the test above . ...
Their assertion would have been true if the metering was done with the lens stopped down. However, Nikon expressly prevents this method for any lens having an aperture coupling of the mechanical kind. The mothership does this for several reasons the discussion of which would severely derail this thread, so I leave them out for now. Suffice it to say that the behaviour is intentional. The only lens kind that might allow this would be the PC-E lenses and for these, excepting for the metering accuracy it doesn't matter whether the lens is stopped down or not when a meter reading is taken.
Bjørn Solberg
« Reply #16 on: April 03, 2017, 11:41:51 »
I think I agree with Kjetil that there is a mechanical problem with the lens (not short circuit though).
I enclose some pictures to illustrate, but again limited knowledge and experience, make this my  guessing.
Assume the lens needs a skilled mecanic, and a dishonest seller was lucky (and I'm learning).
A picture taken with the lens from Palmela in Portugal yesterday is also enclosed.
« Reply #17 on: April 03, 2017, 11:52:01 »
Everything looks normal and shipshape in my eyes.  Could have been pictures taken straight off my own specimen of that lens.
Set the lens to f/16 and see if the aperture has closed down all the way. Push the aperture open by lateral movement of the aperture lever, the aperture should open up freely. Let go of the lever and the aperture blades should snap right back.
If the lens ticks all the boxes above, I see no obvious sign of damage to it.
Bjørn Solberg
« Reply #18 on: April 03, 2017, 13:00:08 »
OK, thanks again Bjørn, it moves freely, sounds and feels OK, when moving aperture lever.
I give it a rest until I'm home in Norway, and can test the lens on another D3s.
I'm quite comfortable shooting with my only other lens, fixed on aperture 2.5, iso fixed at 200,
I adjust time manually, an focus manually. Gives a sense of control, and ability to adjust accordingly,
but no skills in post processing yet.
Bjørn Solberg
« Reply #19 on: April 23, 2017, 15:47:28 »
Lens is OK, works fine on a different D3s. Thanks
« Reply #20 on: April 23, 2017, 21:35:15 »
Statue in Setubal - I'd keep that shot. Nice.
