Author Topic: I've fallen for manual focus lenses and I blame all of you!  (Read 67323 times)
RonVol
Re: I've fallen for manual focus lenses and I blame all of you!
« Reply #45 on: March 16, 2017, 23:07:51 »
Fisky
What's the mounting surface you're using in the shots of the 8mm Erik.
I really like the reflection it's producing :)
« Reply #46 on: March 16, 2017, 23:15:38 »
Thanks! Yes they really go well with the fisheye, I can post a few more, I believe it was part of a kitchen appliance,,,
RonVol
« Reply #47 on: March 16, 2017, 23:32:56 »
Do you mean a kitchen appliance as in a bench top of some kind, or an electrical appliance?
chris dees
  • Amsterdam
« Reply #48 on: March 17, 2017, 00:11:39 »
Should be:
10.5 Nippon Kogaku Nikkor-P (Sonnar)
105 Nippon Kogaku Nikkor-P (Sonnar)
105 Nikkor-PC AI-d and chipped (Gauss or more accurately Xenotar)
All the chrome barrel 105s are the older Sonnar design. The Xenotar lenses have a slightly longer barrel are found in the black barrel Nikkor-P, P.C, K, AI and AIS versions.
Ah.. never too old to learn. :)
Chris Dees
« Reply #49 on: March 17, 2017, 11:01:32 »
Yes I think it was a heat shield from a electrical stove or something like that,,,  :o
gryphon1911
  • Looking For The Best Light
« Reply #50 on: March 19, 2017, 02:56:03 »
I just cannot get enough of this lens.  Bolted onto the PEN-F today and visited a living historical farm.
Andrew
Robert Camfield
  • Hello from MadTown
« Reply #51 on: March 20, 2017, 02:34:55 »
I leave the HN-7, HS-8 and HS-14 hoods in place in the shooting possition at all times and cap them with Tupperware #G Tumbler caps. There is one exception and that's the 105/2.8 AIS Micro when the hood might interfer with light on the subject. I don't like to mess with hoods and I don't like to shoot without them. I don't even reverse the hood on my AF-S 105/2.8G ED-IF VR Micro. My secret fear is Nikon will release a replacement for that lens that is both smaller and apochromatic and I won't be able to afford it.
Regarding shades for 105's: Nikon offered a screw-in lens shade for 105 2.5/135 3.5/105 4.0 lenses, referred to as HN-8. The appearance of the HN-8 shade is virtually identical to the HS-8 snap-in shade. Though somewhat difficult to find, the HN-8 resolves the issue of wobble/insecurity. I've acquired 3-4 over the years, and they work well shades.
« Reply #52 on: March 20, 2017, 06:13:42 »
The HS-4 does not seem to wobble though.
« Reply #53 on: March 20, 2017, 07:54:53 »
The HS-4 didn't wobble. What I remember is one could bump the hood with your hand or one of the chrome buttons and of it would come. Also if a pretty girls walked by it would jump off of its own volition just to make me look like a fool.
I would remove a screw and increase the tension on the threaded spring part and that helped some but that wasn't a fix. The only reason I'd have one of those old snap on hoods was as a collectable. I would not use one for photography.
gryphon1911
« Reply #54 on: March 23, 2017, 15:40:12 »
Ok....so I don't "need" any manual focus lenses....and I'm going to get probably both of these eventually.  If you could get one of these right now which would you get first.
Nikon 55mm f/1.2 or the 180/2.8
There is a shop close to me and they have both on the shelf.  I've done some research and have a good haggling price structure setup....just don't know which one to pull the trigger on first.  kind of leaning toward the 55mm first.
Andrew
« Reply #55 on: March 23, 2017, 15:53:34 »
I have both of those, and I use the 55mm much more. I just don't have many subjects around that 180mm is useful for. However, I've heard that the 50mm f/1.2 is a better lens than the 55mm, so sometimes I feel I should trade up. I don't feel that way about the 180/2.8 ED.
Buy both and sell the one you don't use!
gryphon1911
« Reply #56 on: March 23, 2017, 16:11:04 »
That is kind of where I was leaning too...They also have some inexpensive 24/2.8 I might pick u pas well...see if I can make a bundle deal of some kind.
Thanks for the response.
Andrew
« Reply #57 on: March 23, 2017, 17:08:36 »
Get the 180 if it is the ED version, maybe pass on it if it's the 'regular' 180/2.8.  Extra bonus points for the 180 ED:  It works really well on DX and mirrorless DX.
Get the 55/1.2 if you want to play with the dreamy look wide open.
gryphon1911
« Reply #58 on: March 23, 2017, 17:41:18 »
I'm going to make it difficult on myself and muck about with both in store.  :D
Andrew
Matthew Currie
« Reply #59 on: March 23, 2017, 19:41:01 »
I'm enjoying this thread, but confused by one thing. The assertion has been made that the 105/2.5 is especially suited to the Df, which implies that it is not so well suited to everything else.   If somewhere there is a Nikon camera that does not grab on to this lens like sulfuric acid to a drop of water,  please let me know so I can avoid it.
