Author Topic: Carl Zeiss Planar 85mm f/1.4 for landscapes on Nikon D810:is it a right choice?  (Read 30241 times)
Jedi
  • Let the light be with you!
Upload them to a site like flickr and simply click on the share button, then past in the BB code. Like this:
20170227-DSC_5528 by Daniel Han, on Flickr
(Loving my 70-200 FL :D)
Notice that one may also click on the image, it links to the original upload and one can enlarge it for the comparison you've been talking about.
As for an 85mm for landscapes, I'd personally just recommend the small Voigtlander 90mm f/3.5 Apo-Lanthar. It's made in the same plant as those Zeisses... Zeissi eh... lenses. Cosina makes them.
I try with Imageshack.....
Nikon D810 - Zeiss 21/2.8, Zeiss 25/2, Zeiss 28/2, Nikon 28mm f/2 AI, Zeiss 35/1.4, Zeiss 50/1.4, Zeiss M-P 50/2, Zeiss Milvus 50/1.4, Zeiss 85/1.4,  Zeiss M-P 100/2, Nikon 105/2.5 AI, Nikon AF-D 105/2 DC, Zeiss 135/2, Nikon AF-D 135/2 DC, Nikon AF 200/4 Micro Nikkor.
Macro_Cosmos
    • Flickr
Yep, any image hosting website would do.
Blog: Diatoms Australia
Jedi
Jedi
The 6030.jpg is with 70-200mm f/2.8 VRII FL, while the 6027 is with the Nikkor AF-S 85mm f/1.4G
Good luck!!
Jedi
Good luck!!
Macro_Cosmos
    • Flickr
http://it.tinypic.com?ref=2vijyvp" target="_blank"><img src="http://i64.tinypic.com/2vijyvp.jpg" border="0" alt="Image and video hosting by TinyPic"></a
http://it.tinypic.com?ref=34rhppj" target="_blank"><img src="http://i64.tinypic.com/34rhppj.jpg" border="0" alt="Image and video hosting by TinyPic"></a
Your photos aren't showing up in the forum post. Here, I'll do it for you. Or you can update your post by using the code which is provided on the left hand side of your webpage.
Nikkor AF-S 85mm f/1.4 G  1/250s   f/8   ISO 64   D810
Nikkor AF-S 70-200mm f/2.8E VRII FL   1/250s   f/8   ISO 64    VR ON   D810
Macro_Cosmos
    • Flickr
Good luck!!
From your webpage, I can't see which photo is taken with which lens. Presumably the one a bit wider is the 70-200 FL since a zoom at 85mm may be a bit off?
Jedi
Can I send you the files of the two images, please? I can't do anything.....
Jedi
below with 70-200 f/2.8 VRII FL
CanI send you the files of the images, please? Can you post them  for me on the forum?
Macro_Cosmos
    • Flickr
You can modify your post, there's a little button on the top right corner of each post.
Paste the code enclosed in the (IMG)(/IMG) code, square brackets instead of curved ones. Or just simply tell me which photo is with which lens.
Jedi
the first, ABOVE, is with Nikkor AF-S 85mm f/1.4 G  1/250s   f/8   ISO 64   D810
the second,  BELOW, is with Nikkor AF-S 70-200mm f/2.8E VRII FL   1/250s   f/8   ISO 64    VR ON   D810
Macro_Cosmos
    • Flickr
Thanks, I'll modify that post.
Jedi
Jedi
I think my D810 hasn't issues with AF, because with all the others my AF lenses, to infinity, the results are perfect. My 85mm at portrait-distance, is great-performer,  is very sharp. However, I noticed the tha MAF with the central sensor of MAF is perfect, precise, while sometimes it isn't perfect, it is indecided, uncertain , with lateral sensor, BUT ONLY WITH THE 85mm, also in good light conditions.....
simsurace
I don't see anything special with these small-sized images.
In general, when you want to evaluate lens sharpness you have to control for focus error.
It is best to focus manually with live view.
AF having a problem (i.e. being imprecise at far distances) is a different matter than the lens being unsharp by design or due to mechanical problems!
Simone Carlo Surace
suracephoto.com
