Author Topic: January 2017  (Read 70195 times)
Re: January 2017
« Reply #180 on: January 25, 2017, 15:23:40 »
Thanks Akira.
For some days now it  is cloudy and cold.  The cold weather is no reason to cancel the Open Air  market. There are heating lamps to make the purchasing a more pleasant occasion...
D600   300/4.5 ED-IF  AIS
Re: January 2017
« Reply #181 on: January 25, 2017, 18:58:40 »
Thanks Akira.
Strange mixture of WB points. The man with the plaid hat looks best to me. I wonder how the D500 might have solved this... one of the really big differences in the new generation...
Re: January 2017
« Reply #182 on: January 25, 2017, 19:13:58 »
January 23/30
.curly whirly.
25 01 02017
I took a lot of interesting shots today, but this one is different. Somehow it makes me woozy when I look at it and it touches me emotionally too, So I chose it. I see a tendency towards monochromatic shots.
technical: D500 & 1.4/24 @f/1.4
Re: January 2017
« Reply #183 on: January 25, 2017, 22:46:29 »
It's not something of WB points, Frank.  The man is standing in a yellowish light, and the lens and sensor captured it as it was. It is a mix of different light.   The point here is the post-processing.
It was quit dark, and for a 300mm the shutter speed goes up, took some risk with 1/200,  hence an increase in ISO to 720. Every increase from base ISO limits to a certain extent the post-processing possibilities.
For this picture, I did some framing to focus on the people behind the stall as I wanted to emphasize, the eagerness (or perhaps hurry) to pay, or to do the purchase quickly. So I wanted all neutral visible in the image, meaning the man in the yellow spotlight, decrease in lightness, and the others a slight decrease of the shadow.
Many ways are possible to post-process it.    On Flickr I uploaded a natural version in the originale frame which reflects the cold morning atmosphere in a different way.  https://www.flickr.com/photos/fisherking/32145379850/in/dateposted-public/
Re: January 2017
« Reply #184 on: January 26, 2017, 02:57:53 »
It was quit dark, and for a 300mm the shutter speed goes up, took some risk with 1/200,  hence an increase in ISO to 720. Every increase from base ISO limits to a certain extent the post-processing possibilities. On Flickr I uploaded a natural version in the originale frame which reflects the cold morning atmosphere in a different way.  https://www.flickr.com/photos/fisherking/32145379850/in/dateposted-public/
I like the Flickr-version MUCH MUCH better!
I like the framing and the more intimate atmosphere. Just perfect & much better in my eyes than the version above!!!
Re: January 2017
« Reply #185 on: January 26, 2017, 12:33:58 »
January 24/30
.double spread.
26 01 02017
To me double tree trunks sometimes look like legs. I took this because two double trunks, one behind the other, seem quite unusual to me.
annotation: I might have closed the aperture a bit more
Re: January 2017
« Reply #186 on: January 26, 2017, 22:56:14 »
Sunny and cold. The frost is visible in our place in fountains and frozen water pools
The Spoorzone, the former Railway factories, is still a deserted place.
Re: January 2017
« Reply #187 on: January 27, 2017, 12:20:45 »
John: Perfect moment, movement, position, color scape!
Re: January 2017
« Reply #188 on: January 27, 2017, 12:29:14 »
January 25/30
.75.
27 01 02017
German architecture of the 1950ies is unloved, mostly unprotected, build with very bad material and therefore replaced without further consideration. I try to fixate some typical examples with my cameras before they disappear completely. I chose this picture for today because the window decoration seems to be a hint that someone is living here since the house was built!
technical: D500 & Neo-Noct @f/1.4
Re: January 2017
« Reply #189 on: January 27, 2017, 16:47:27 »
Re: January 2017
« Reply #190 on: January 27, 2017, 17:05:34 »
Hi Fons:
Looks like a full value breakfast ;-)
Love to see you back here!
Re: January 2017
« Reply #191 on: January 27, 2017, 18:57:48 »
Thanks Frank.
Love the 50's architecture.  I always assumed it was rather good in quality. (sustainability)
Nice collection Fons.  Unusual beer brands.  From far away?
We still have sun and frost, but clouds, and above-zer0-weather is approaching.
City-transportation.  (like the two before D600 - 300/4.5 ED-IF AIS -  the poor man's  PF  ;)   )
Re: January 2017
« Reply #192 on: January 27, 2017, 20:33:37 »
Welcome back, Fons!  Too much beer for me to toast your return, though.    :D
John, nice atmosphere.
Re: January 2017
« Reply #193 on: January 27, 2017, 21:52:19 »
John. They had to re build a lot after the war and the material was often of poor quality. There were people with old money who used cheap labour to build with expensive, lasting material. But most were poor and got what they could afford. So you can hear the neighboours having sex two storeys away because walls and ceilings are only as thin as needed to survive daily life for some decades. These houses lose heat. No insulation. You heat the outside more than the inside
Re: January 2017
« Reply #194 on: January 28, 2017, 09:42:29 »
Thank you Frank, Akira, John
They came from Lidl in a box, classical ales, pre-brexit stock i think.
