Author Topic: AFS 60 micro AF very sick  (Read 6487 times)
PedroS
« on: December 06, 2016, 18:29:21 »
Mine 60mm micro AFS is sick; it's an AF problem... 8 years old...  :o
Sometimes it works, sometimes it rests... and on all my bodies.
Yes, I have cleaned the contacts.
Question is; is this lens easy serviceable or should I send it to more knowledgeable people?
Re: AFS 60 micro AF very sick
« Reply #1 on: December 06, 2016, 18:55:10 »
Nikon service will take good care of it :)
« Reply #2 on: December 06, 2016, 19:44:10 »
I had that with my 60G after excessive use. AF was totally stuck. Nikon repaired it for roughly 100 Euros.
PeterN
« Reply #3 on: December 09, 2016, 19:46:53 »
Funny, mine is a year old. I have used it quite a few photos and experience similar problems.
Is this lens specific?
Peter
PedroS
« Reply #4 on: December 09, 2016, 19:49:48 »
Well from my big pack of AFS that's the only one with problems...
JJChan
  • JJ Chan
« Reply #5 on: December 14, 2016, 03:30:45 »
Pedro
I've had 2 AFS lens failures in the last 18 months.
My 300 f4 motor failed and will cost too much to fix (estimated at AUD$500). That was from underuse?
My made in Japan 60mm which I used daily at work stuck around 30cm focus distance - I mainly use it from 30-100cm focal distance. It then stopped AF altogether. That was also estimated to cost AUD$500 to fix. I bought that new about 8 years ago.
I'm currently in HKG and picked up a new 60mm AFS - made in Thailand for AUD $620 - and it focuses far faster and much more smoothly than my previous lens did. I think it has been upgraded internally since it first came out.
So if you use this lens daily as I do, a new one may be better than an old one repaired (I can't get it fixed cheaply in Australia anyway)
JJ
« Reply #6 on: December 14, 2016, 03:34:18 »
you might've gotten a lemon :o :o :o
« Reply #7 on: December 14, 2016, 09:16:59 »
That makes 3 lemons in one thread....
PedroS
« Reply #8 on: December 14, 2016, 10:01:12 »
Pedro
JJ
That's a fair point.
Thanks
« Reply #9 on: December 14, 2016, 12:12:10 »
Yet many people complain when a new lens (105/1.4) doesn't come with this type of a failure prone motor. I don't understand.  ???
PedroS
« Reply #10 on: December 14, 2016, 14:58:47 »
A lemon tree... perhaps  ;)
« Reply #11 on: December 14, 2016, 15:44:24 »
one thing I can say is that many of the 1st gen AF-S lenses have developed some form of problems connected to the AF motor. :o :o :o
cases that I have knowledge about (friends/acquaintances,stories from the shop and reading the net):
28-70 (known)
17-55 (known)
80-200 AF-S (known)
60mm (from this thread)
70-200VR 1st gen (1 case, from a repairman friend)
what do you guys think? is it fair to put the earlier 60mm into the "known" list? my friends' 28-70 and 17-55 haven't developed any problems since but then i lost communication with some of them or they have sod their lenses. any opinions?
« Reply #12 on: December 14, 2016, 15:49:53 »
simple is best  ::)
i wonder. will that give us new problems instead? :o :o :o
« Reply #13 on: December 14, 2016, 16:32:47 »
The ring ultrasonic motor was introduced into camera lenses by Canon in 1987 (300/2.8 ) or so (first use by Nikon 300/2.8 in 1996 I think). A 2008 release (60mm f/2.8 AF-S Micro; 21 years after the first Canon lens) should  not be excused as suffering from "1st generation" problems of this technology.
« Reply #14 on: December 14, 2016, 16:34:33 »
simple is best  ::)
I would think that replacement is easy since the motor is at the side of the lens instead of around it.
