Author Topic: IR-665 Nubble Light  (Read 2999 times)
IR-665 Nubble Light
« on: June 26, 2015, 01:32:21 »
IR from the past..
Nikon D200 ,Nikkor 16mm f/3.5 AI Fisheye
1/640s f/5.6 at 16.0mm iso160
Re: IR-665 Nubble Light
« Reply #1 on: June 26, 2015, 08:21:15 »
  The birds give it a temporality that makes me keep looking.  It could almost not be false color.
« Reply #2 on: June 26, 2015, 09:39:58 »
Did yopu somehow choreograph the birds? A WOW moment.
« Reply #3 on: June 26, 2015, 10:23:30 »
Uusually I for one try to avod blue sky when processing IR captures, as IR should add a layer or extra dimension of alienness to the outcome. Once in a while I'm glad to be proven wrong and that there are situations in which an apparent closer resemblance to the visible works  ;D
knb
« Reply #4 on: June 26, 2015, 12:22:18 »
As Keith says, it does really look like normal vision. The selection of birds does the trick of course, especially with this deep DOF.
Kjetil Narum Bakken
Andrew
« Reply #5 on: June 26, 2015, 13:27:32 »
Very well done, is quite different from results with "720" filter.
Andrew Iwanowski
« Reply #6 on: June 29, 2015, 09:37:56 »
Just the right moment with the birds and very good PP!
