Author Topic: My new 'UV' Nikkor  (Read 4740 times)
My new 'UV' Nikkor
« on: October 24, 2016, 22:35:26 »
Well, at least I do hope it is good for UV applications !! The optics are dating from early '60s, there is no multicoating and only 4 elements, and none of them are cemented. Filters can be added to the rear end of the lens head yet are protected inside the focusing barrel. All of which taken together is a promising starting point for some severe UV work.
Here is the 400 mm f/4.5 Nikkor-Q with the focusing adapter CU, complete with boxes etc. The price was ridiculously low probably because the less fashionable CU focusing adapter is part of the assembly. However that will not bother me as I already have the more modern AU-1 unit ready for the new lens head.
The lens is currently in transit so will arrive in a week or two ahead, unless the Norwegian Customs throw their usual spanner into the works. Then days fly by before the item has cleared customs.
The reason I like to put this long lens, incidentally not a telephoto design just a long focal length unit, into service for UV and/or IR is the available long lenses for UV are scarce as hen's teeth. UV extends beyond documentation of botanical subjects, however nice these appear in UV.
(and yes, I already own several genuine UV-Nikkors so no need for more of them)
Re: My new 'UV' Nikkor
« Reply #1 on: October 24, 2016, 22:40:01 »
Wow that looks mint! Congratulations ;)
« Reply #2 on: October 24, 2016, 22:43:15 »
Just USD 570 with shipping for a pristine sample, not bad. Not bad at all.
« Reply #3 on: October 24, 2016, 22:51:25 »
Congratulations, Bjørn, looking forward to the results :)
Bill De Jager
« Reply #4 on: October 25, 2016, 02:33:24 »
I got one of those and did a quick visual check before setting it aside for some time.  It seemed to have a weird rendition quite unlike other lenses that pass some UV.  I may have a bad sample.  In any case, I'm eager to see what you find out, Bjørn!
« Reply #5 on: October 25, 2016, 02:38:56 »
At that low price I'm more than willing to take a chance ... and it being 'weird' sounds promising in my ears !!
I expect it to have significant chromatic aberration in UV, though. But for experimental purposes that'll be OK I guess.
« Reply #6 on: October 25, 2016, 04:10:55 »
looks interesting :o :o :o
i would like to open one up. i hope that i find one in the junk box ::)
« Reply #7 on: October 26, 2016, 00:34:25 »
I'm happy for your find and may the gods of focal shift be on your side Bjorn!
« Reply #8 on: October 26, 2016, 00:36:05 »
With a narrow-band filter attached to the lens head, I hope for the best as well, Klaus.
« Reply #9 on: October 26, 2016, 00:36:22 »
Looking for seeing the result, Bjørn!
« Reply #10 on: October 27, 2016, 11:38:04 »
I have found a really solid way of using the CU-1 focusing attachment for these lens heads without the focusing helicoid being stressed.
The original supports for the CU-1 are nowhere to be found just like the AU-1 they are very scares!
I will be using the beefy lens rail I used for the 6mm F/2.8 Video relay
http://nikongear.net/revival/index.php/topic,3011.msg50284.html#msg50284
It is about 28 cm long so a little shorter than the Cu-1 which is about 30 cm
At the end, close to the camera mount I will mount this Markins York 10-VR L, the roller will let the lens slide back and forth as the lens is focused since it's not an IF,,,
« Reply #11 on: October 27, 2016, 11:45:26 »
I will of course modify the York to enable fully adjustable height setting, the Markins have chosen a clamp arrangement that can rotate, and I want to eliminate that since their design doesn't allow for linear movement of the lens itself. In my setup the rail will be parallel to the lens.
« Reply #12 on: October 27, 2016, 11:46:42 »
Superb, Erik. That appears a most viable solution.
There is a bonus 600/5.6 Nikkor lens head in store for you ... And probably a CU unit as well, once I get my new 400 and the current AU-1 is modified to host multiple CPUs.
« Reply #13 on: October 27, 2016, 11:50:30 »
I can hardly wait to put my hands on it,,, should be good for [IR] I guess? Again Very generous of you Bjørn ;D
Looking forward to the multiple CPU challenge also ;)
« Reply #14 on: October 27, 2016, 11:54:59 »
No idea, but you'll find out in due time.
Anyway, I have two 600/5.6 Nikkor lens heads and only need one of them. You have none. It's really that simple.
