Author Topic: Nikkor-O 35mm f/2  (Read 47978 times)
Peter
  • Los Alamos, New Mexico
Re: Nikkor-O 35mm f/2
« Reply #60 on: November 01, 2016, 16:20:05 »
Peter, are these taken with the Nikkor 35/2 O?
Bjørn,
Yes they are sorry I made the correction.
I was using a Sigma Mini Wide II 28mm before hand and didn't reset the Non CPU lens Data to the 35mm f2 setting.
The lens size does not show up on Capture NX-D only sequence number, aperture and shutter speed.
My Bad. ::)
Pete
« Reply #61 on: November 01, 2016, 17:21:31 »
One out of many reasons we put CPUs in the old lenses ...
Just retrieved my old 35/2 O from its long hiding place so haven't modified it yet. A job for Erik next time I meet him as it also needs to be properly AI-modified and he does a marvellous job with such stuff.
Peter
« Reply #62 on: November 01, 2016, 18:05:58 »
Just retrieved my old 35/2 O from its long hiding place so haven't modified it yet. A job for Erik next time I meet him as it also needs to be properly AI-modified and he does a marvelous job with such stuff.
I agree, I am looking for another 35 f2 to do CPU chip.
Mine works well but has some glass issues minor as it is and I personally don't see any effect to my images I feel if I am going to spend the time and money for a chip it should be done on a clean lens.
Thanks for the catch Bjorn.
Pete
« Reply #63 on: November 02, 2016, 00:57:55 »
just bought an HN-3 for my 35mm f/1.4 Ai-S. it works nicely with the Nikkor-O 35mm f/2 :o :o :o
for general street photography, i actually prefer the Nikkor-O 35mm f/2 over the 35mm f/1.4 Ai-S because of the longer throw and smaller size.
« Reply #64 on: November 02, 2016, 01:16:34 »
The AI 35/1.4 has a longer focus throw - 180° vs 105°
But it only has 7 aperture blades compared to 9 for the AIS (not rounded though)
« Reply #65 on: November 02, 2016, 03:04:16 »
unfortunately, not in the market for that at the moment. the wallet is still crying from last weekend's purchase (of the 35mm f/1.4 Ai-S)  ::)
the Nikkor-O 35mm f/2 is very versatile. it is quickly replacing the 35mm f/2.8 lenses that I have for everyday carry. however, the f/2.8s are smaller and a lot  more discreet :o :o :o
the only reason for me to have the f/2 is to shoot at f/2.
« Reply #66 on: November 02, 2016, 05:56:11 »
I've never shot a 35/2.8 but I've shot the 35/2.0 Nikkor-O and 35/2.0 AI. I prefer to shot the 35/2.0 at f/2.8 to f/5.6.
I probably chose the f/2.0 for a bit faster lens since I started two Nikon systems with a 55/3.5 Micro. The 35/2.0 helped with speed as a wide normal to cover for a slow normal.
Someday I'd like to pickup a 105/2.5 Nikkor-P and 35/2.0 Nikkor-O for old time sake. I'd also like a 20/3.5 Nikkor-UD. Is it OK to own four 20mm lenses?
« Reply #67 on: November 02, 2016, 07:16:28 »
Dave, you have my special permission!  I have four plus a 21mm.  The 20mm/3.5 UD is beautifully made and is a good lens.  Slightly heavy.
My 35mm f/2.0 is an AIS with more modern coatings, so I suspect that its character and flare properties are different to the Nikkor-O 35mm f/2.  It does however have an 8E/6G lens element setup.
« Reply #68 on: November 02, 2016, 08:37:40 »
As I recall the 20/3.5 UD filled the hand nicely and balanced well on the F or F2. It displayed ghost but wasn't bad concerning flare. Also I think the distortion was rather tame. It was the widest lens I own with my first Nikon system. Mine came with a 72mm metal screw in lens cap.
« Reply #69 on: November 02, 2016, 12:24:30 »
CPU modification to the rescue! Can't live without it :)
« Reply #70 on: November 02, 2016, 13:04:55 »
It's off topic here, but I regard the UD as the best (as in general terms) manual 20mm Nikkor. Crisp and detailed images on the D800E with very little distortion.
« Reply #71 on: November 03, 2016, 02:27:00 »
currently writing the teardown for this, by request :o :o :o
« Reply #72 on: November 05, 2016, 15:17:11 »
https://richardhaw.com/2016/11/05/repair-nikkor-o-35mm-f2/
OK, by special request of some of our friends here :o :o :o
« Reply #73 on: November 05, 2016, 22:40:51 »
Very nice work.
« Reply #74 on: November 06, 2016, 00:43:10 »
Very nice work.
Thanks, Bent!  :o :o :o
Glad you liked it.
by the way, i mentioned in the article that I have seen 3 lenses with the same problem as mine in the junk shops. looks like it is a common ailment for this lens. probably it's weakness.
