Author Topic: Nikkor-O 35mm f/2  (Read 48219 times)
Re: Nikkor-O 35mm f/2
« Reply #45 on: October 31, 2016, 21:22:33 »
Flare resistance never was a strong point of the 35/2.
This the result, had to change the exposure -2.0 as it seems the D500 lightmeter was fooled by the strong side light.
The flare is still clearly visible.
I actually like to use this old-timer on the brand new D500  :)
« Reply #46 on: October 31, 2016, 21:30:23 »
Flare like that can usually be controlled just by using your hand to cut off the troublesome light rays.
« Reply #47 on: October 31, 2016, 22:12:43 »
Yes, but I wanted to see how bad it was. The file direct out-of-camera was even worse as the meter did an over exposure.
« Reply #48 on: October 31, 2016, 22:18:06 »
If you *really* want to see horrendous flare, just shoot the same scene in IR ...
« Reply #49 on: November 01, 2016, 04:16:08 »
the flare problem persisted through the AF-D version? :o :o :o
Peter
  • Los Alamos, New Mexico
« Reply #50 on: November 01, 2016, 06:50:35 »
B&W or Color?
Shot with Nikkor-O 35mm f/2.
I try to keep this lens out of the sun as well.
Or like Bjørn stated your hand, or I use my Lastolite portable gray card it comes in handy.
« Reply #51 on: November 01, 2016, 06:58:22 »
Take your pick.
I try to keep this lens out of the sun..
color  :o :o :o
Peter
« Reply #52 on: November 01, 2016, 07:06:37 »
color  :o :o :o
Me to but Like the drama as well!! ;)
« Reply #53 on: November 01, 2016, 07:07:55 »
Colour :)
Peter
« Reply #54 on: November 01, 2016, 07:22:24 »
You wouldn't know it but this is what is about 200 yards behind this metal building.. It is truly a sight to see..
https://en.wikipedia.org/wiki/Rio_Grande_Gorge
« Reply #55 on: November 01, 2016, 11:58:42 »
Nice colour shot indeed! But works I B&W also naturally - What a location, would love to go there and shoot away!
« Reply #56 on: November 01, 2016, 12:07:43 »
In this particular case, I won't hesitate to pick the color version.  The stunning red accent is hard to avoid.
« Reply #57 on: November 01, 2016, 12:11:10 »
Peter, are these taken with the Nikkor 35/2 O?
« Reply #58 on: November 01, 2016, 12:31:31 »
Exif says 28mm.  The lens info is mis-set?
« Reply #59 on: November 01, 2016, 12:39:08 »
I'm asking because these pictures were posted in another thread and no reference to the 35/2 O was seen there.
A thread dedicated to a given lens should be kept clean of other focal lengths, however successful those images might be. Only exeception would be shoot-outs comparing different lenses, though.
