Author Topic: 1200mm f/11 Bazooka  (Read 11825 times)
BW
    • Børge Wahl-Photography
Re: 1200mm f/11 Bazooka
« Reply #15 on: October 09, 2016, 22:09:22 »
Thats not a big lens. This is. Unfortunately its a Canon. Shitty optics ;)
« Reply #16 on: October 09, 2016, 23:42:02 »
Hahahaha, Børge, tell me more about this packaging for shit :D
Where did you capture it???
Mongo
« Reply #17 on: October 10, 2016, 00:15:40 »
actually BW, Mongo is quite impressed with this. The build quality and optics have an excellent chance of being better than some Nikkors Mongo has purchased in the past.
BW
« Reply #18 on: October 10, 2016, 06:40:55 »
It`s in Trondheim, Norway. I saw it driving by in a boat. I don't know what it is so, naturally I assumes it was a discarded Canon lens of the less portable kind :) It is certainly worth a closer look. But now we`re way off topic..
« Reply #19 on: October 10, 2016, 12:36:23 »
Sorry, really busy to reply :(
saw some sample images of this lens and the performance is not as good as i hoped but i can imagine this lens opening lots of possibilities before.  :o :o :o
this looks like it belongs on the rollbar of a landrover fitted with a custom mount
« Reply #20 on: October 10, 2016, 14:17:56 »
An example with the 1200/11 ED-IF is posted here:
http://nikongear.net/revival/index.php/topic,4483.msg70860.html#msg70860
Do note the shutter speeds ranged from 1/8 to 1/15 sec ... A challenge to sort the adequate from the inadequate as far as tripod support is concerned.
« Reply #21 on: October 14, 2016, 03:42:37 »
by the way, i Gave the sn to Roland Vink and he confirmed that this is indeed one of the rarer ED version but the focusing unit is that of the older type, am I correct? :o :o :o
« Reply #22 on: October 14, 2016, 14:19:10 »
The ED version of the 1200/11 lens head is very rare and probably performs well, if the 800/8 ED is anything to judge by (amazingly sharp long lens). However, where is the golden ring to signal the lens is ED? Not visible in the opening photo.
The old adapter is well-nigh useless with any of the lens heads except for the 400/4.5 Nikkor. The reason is that Nikon made the helicoid way too short and the leverage of the longer lens heads will make the helicoid stick or bind badly. Get the newer AU-1, it works like a charm.
« Reply #23 on: October 14, 2016, 14:27:20 »
What is the Sn# on this lens ?
Not many AU-1 on the marked,,,
« Reply #24 on: October 14, 2016, 14:53:45 »
... Not many AU-1 on the marked,,,
So very true. I had to buy another 600/5.6 Nikkor lens head in order to get the AU-1 it was attached to. Thus I now own both adapters and have duplicate 600/5.6 Nikkor-P lens heads. I will give away the 600/5.6  - for free - to any party interested ... if Erik refrains from picking it up first ....
« Reply #25 on: October 14, 2016, 19:46:23 »
I have looked high and low but no AU-1 anywhere I can see,,,  :-\
« Reply #26 on: October 15, 2016, 01:04:11 »
Below is a picture of a 1200 ED I saved from ebay, it has a gold ring between the tripod mount and aperture ring. The aperture ring has a square-pattern grip similar to K and AI lenses. The lens Rick posted looks very similar, but no gold ring in the same place, and the aperture ring is the old scalloped style, so I'd say it was not the ED version. Either they gave the wrong serial number, or we have an ED lens put into an old barrel, or ED serial number put on a non-ED lens (which is unlikely since they are different optically and unlikely that parts can be interchanged)
« Reply #27 on: October 15, 2016, 01:23:38 »
That is how my 800/8 ED lens head looks, apart from being shorter. Thus the lens illustrated in the opening post is not an ED type.
« Reply #28 on: October 15, 2016, 09:32:19 »
Hello. I cannot find the image in the outbox so Inwill ask Roland for the serial again. Yhe serial falls in between the sn on his database. :o :o :o
¥120,000 is also a nice price according to another collector friend of mine considering that it comes with that casket looking box.
Can it be that this is an interim version? ::) i know nothing about this lens
« Reply #29 on: October 15, 2016, 09:36:50 »
Ok, i found the picture of the sn. I asked the shop to check their records and they gave me this :o :o :o
They usually don't give out sn but i am a good customer  ::)
