Author Topic: Has someone photos of...  (Read 4518 times)
PedroS
« on: September 26, 2016, 11:46:26 »
I'm going to try new options in lighting products.
The Profoto Probox seems very promising, but I would like to understnad how they work. What I do know is that they provide an event light from corner to corner.
So if someone has experience or, even better some photos of their interior, I appreciate if you can share them with me.
Thanks
Re: Has someone photos of...
« Reply #1 on: September 26, 2016, 13:05:44 »
Couldnt you ask about something more affordable!! :)
Okey - I also want to know the answer to your question :)
PedroS
« Reply #2 on: September 26, 2016, 14:12:32 »
At around $1,000.00 each (B&H) they are absolutely affordable  :o
« Reply #3 on: September 26, 2016, 16:12:35 »
wow ... it's a softbox
Almass
« Reply #4 on: September 26, 2016, 17:00:27 »
Actually it is a Hard Box  ;D
 I use Profoto gear but not this one.....it is more intended for studio table top shooting.
PedroS
« Reply #5 on: September 26, 2016, 18:52:09 »
It looks like ... but, I believe internally, it should be different
« Reply #6 on: September 26, 2016, 20:11:48 »
alas - the Profoto gear is out of my (bank manager's) reach.
Pedro - $1000 is probably cheap - if you are sufficiently padded in the financial department
PedroS
« Reply #7 on: September 26, 2016, 20:36:43 »
I was sarcastic...
charlie
« Reply #8 on: September 26, 2016, 20:39:57 »
I researched this not to long ago to look into building my own, not that I necessarily need a Probox, I just like making things. I did however build my own version of the Profoto Hardbox.
From what I found the Probox has a 2 piece ground glass near the flash head, then a counter reflector with graduated reflective surfaces inside, and a plexiglass/acrylic front. All of which translates to near perfect even light output from corner to corner.  I can think of other ways to get even light output across a 20 x 30 cm piece of acrylic, but it would be tricky to make something as small and convenient as this.
