Author Topic: Gull - Advanced Behavioural Series  (Read 4290 times)
Mongo
« on: September 18, 2016, 09:24:07 »
It seems you cannot help but learn things when you observe them long enough.
This is a very short story of an adult Kelp Gull (AKA the Southern Black-backed Gull). It is quite a robust, strong gull (image #1) but can be also quite an elegant bird (image #2).
Mongo was sitting in front of a small sandstone shoal situated at water level. One of these large gulls was coming from the distance with something in its beak. All the while it was gaining altitude and started to circle the sandstone shoal. As it got closer, it became clearer that the thing in its beak was a local sea creature that looks like a large garden snail (image #3).
At a strategic point in its circling flight, the gull deliberately released the snail which then fell with great precision onto the sandstone below (images #4 and #5).
As the snail fell to the rocks below as intended, the gull began to follow it down (image #6).
The gull followed it down and inspect it. It seemed disappointed and It picked up the snail and again flew high over the sandstone shoal. It again dropped the snail from quite a height. Again, it landed on the sandstone. This time when the gull flew down to it, found it broken open and began to eat its freshly open reward (image #7)
Some time later, either the same gull or another of this species did exactly the same thing with another snail. This was starting to feel like when you first see such a scene in an Attenborough documentary. Mongo was aware that some birds use height/gravity to break open their otherwise hard to get at food. Mongo believed this behaviour was limited to a few far more intelligent bird species. However, now having seem it several time, there can be no doubt that this gull is one of those species.
D800E with nikon 200-500mm and monopod.
Re: Gull - Advanced Behavioural Series
« Reply #1 on: September 18, 2016, 09:54:55 »
Did the gull hit its target on the first try?
Very nice series.
Thank You!
Mongo
« Reply #2 on: September 18, 2016, 10:44:54 »
Very nice series.
Thank You!
Thank you David -  yes, it did but the shell failed to break the first time.
John G
  • "Borrowed a Little Light"
« Reply #3 on: September 18, 2016, 11:52:30 »
Hi Mongo, another set of stunning images, Portraits and Action,  the 200 - 500mm really shines in your hands.
Your a true inspiration for making this a lens choice.
John Gallagher
« Reply #4 on: September 18, 2016, 15:23:10 »
Nicely captured series Mongo and a very informative narrative.  Thanks for this - I have now (almost) seen it with my own eyes thanks to you and the 200-500mm lens that you have been putting to good use.
« Reply #5 on: September 18, 2016, 16:44:46 »
Great feature and story telling.
« Reply #6 on: September 18, 2016, 17:05:59 »
Yet another intriguing documentation of intelligent wild birds.  Needless to say, but the quality of the images are well suited for the "Mongo" brand.
Here in Japan, crows are known to be very intelligent.  I saw a crow in a TV program that picks up a walnut, drops it onto a road and let a car run over it and break it.  The crow ate the fruit inside.
Kim Pilegaard
  • "Nikea"
« Reply #7 on: September 18, 2016, 17:08:40 »
Really nice series of pictures of this very intelligent gull behaviour!
Kim
« Reply #8 on: September 18, 2016, 17:21:19 »
Great series on the Gull behavior...! Perfect pictures  :D
« Reply #9 on: September 18, 2016, 17:34:31 »
Well taken 👍 Great sequence 😎
Tom Hook
  • Tom
« Reply #10 on: September 18, 2016, 18:56:31 »
Nicely done Mongo. Gulls are very resourceful birds and your wonderful sequence shows that quality beautifully.
« Reply #11 on: September 18, 2016, 19:36:37 »
If it was the right kind of cockatoo it would just bust the nut open. Last night my friend's bird unscrewed the lid on a Target Department Store jar that once contained a trail mix. There were raw pistachio nuts inside. The jar is clear. After a couple of tentative tries at getting a nut through the plastic side it started unscrewing the lid.  I let her pick out a half dozen nuts before I moved her away. The lit is about 15cm across. It was loosely but fully closed so she was able to use the tip of her beak. She had watched me unscrew the lit so she started turning it the correct direction on the first try.
Cockatoos name their young. The birds know their names, their parents names and their siblings names. This may be because a mated pair would need to keep track of each other in the rain forest with calls when they could not see each other. What would be better than calling out each others name?
chris dees
  • Amsterdam
« Reply #12 on: September 18, 2016, 19:49:08 »
Very nice series!
You see that behaviour in Holland as well.
Another nice characteristic of  Gulls (adults)  is the very red dot on their beak.
When a juvenile ticks on that dot, the adult will open its beak and throw up some food. 😊
Chris Dees
« Reply #13 on: September 18, 2016, 19:59:46 »
I'll bet the bird has learned that the snail doesn't weight enough to brake the shell by simply dropping the snail, hence the need to drop a rock on it.
Mongo
It's a wonderful series of photos! Thank you for posting.
Mongo: do you accept candy grams?
Sorry, I had to ask at least once. :)
Mongo
« Reply #14 on: September 19, 2016, 01:16:57 »
thank you all for looking in and for your kind and informative comments. Glad you liked the series.
Some specific replies: -
Akira, Mongo also saw that feature about the crow on TV and they are a very intelligent species. Perhaps only parrots are smarter.
David, Mongo does not know what a “candy gram “ is but it sound nice and Mongo is grateful for the thought in any event.
