Author Topic: Summer weather in the Lake District  (Read 4207 times)
simato73
Re: Summer weather in the Lake District
« Reply #15 on: August 21, 2016, 21:46:55 »
Simone - great landscape shots!
I like to shoot landscapes too. I've often found myself struggling with my "honesty" when processing but I increasingly tend to end up with something that is more emotional (or bold..) than honest - more contrast and shadows .. probably something I've taken with me from my film days.
I agree with Jakov - the images should convey your view. The following is just a few thoughts and reaction to the discussion.
In your first shot the light seems a bit hard coming from the side - my own approach wouldn't be to suppress this as such light imho contributes to the contrasts in the image and I would also let the sky stand out more bright.
The shot that Elsa commented on is tricky - shot at long distance and long focal length in such a weather.  It looks honest :)
As for the rest, I do not find them flat - on my monitor they have a good balance. However, lots of green and different green nuances can probably give the impression of less contrast(?).
I also have a Fuji (X-E1) and in the beginning (coming from a Nikon) I found the files to bee a bit tricky to process. A bit desaturated (or flat?) but after a while I got better results when I explored the default "film curve" in my processing tool (Capture One Pro) and took more control of the curve setting. In some situations I choose start with a "Linear response" and then use the curve to mould the light and contrasts in the image. I have only briefly tried LightZone and my memory says that it did not default to a "film curve" - it looked more similar to a linear response.
I've also found the WB to challenge my perception of "correct" - the camera probably knows best but I allow myself some influence. I mostly shoot with film simulation "Provia" and in general I find the WB to lean towards cool.
Thanks Lars, for the kind words about the images and for the interesting thoughts.
I am not too concerned with "honesty" in post-processing. I don't add or remove elements from the picture, but all the rest, from the choice of a point of view, to the perspective, the framing (and sometimes the cropping) and obviously the post-processing is a personal interpretation and is aiming at creating something I like.
The light in the first picture is not too bad for me. I like the shininess of the ferns bent by the wind. The light is a bit harsh, yes, but not flat.
In many other shots the light is not harsh, but the images a bit flat. Some of it has to do with the flattening I have done to manage the dynamic range, but the second one did not have this issue. The greens as you said also contribute to the perceived flatness.
Elsa seems to have peeled off a thin opaque film from the top of the image I had posted. Sometimes I get to that point and am pleased with the result, but other times it seems unnatural and overcooked, probably because I could have done it better, so in the end with most images I tend to be conservative.
I manage my pictures still within Aperture but don't use the Apple RAW engine any longer. My raw files are developed in Iridient and the tiffs further processed in Lightzone, without using Lightzone's raw converter. If (when) I move away from Aperture I might explore more Lightzone also for direct editing of raw files, but I have to say I like Iridient a lot.
Finally, WB. I also tend to find the auto WB a bit too cool, but am absolutely not accurate and not systematic about correcting it. I just occasionally change it to something that looks more or less ok.
Simone Tomasi
« Reply #16 on: August 22, 2016, 07:02:14 »
I am very happy with shots 2,4,5,6 in the opening post because they give me a sense on the size & form of this landscape. .... and they make me long to be there & breathe the air!
« Reply #17 on: August 22, 2016, 07:29:56 »
About the low contrast, it is not generally something I positively want to have, rather the consequence of me trying to get all the detail from the deepest shadows to the highlights. I still have to learn a way to do it in a credible way that does not look flat.
Somewhere something has got to give, I just have to find what and how.
In this search for a balance you, Lars and Elsa are right that whatever the look, if that is my choice so be it. I am still learning - the more photos I take the more it seems there is to learn - and looking at other people's pictures and talking with them is useful.
For me the book "Photoshop Professional" by Dan Margulis was an eye opener years ago. Correct colors, great highlights and shadows, eye pleasing contrast.
Do not be fooled by the title. You learn seeing channels and using layers, things that are common to any advanced editing program, not Photoshop especially.
You can start out with creating a TIFF in Photo Ninja, which I use to treat my Fuji Xtrans2 files from the X100T (same sensor as the XT-1), and later do the fine tunig in any other program.
After these technical notes I want to refer to the artistic decisions:
In film days my "look" was the Fuji Sensia 100 look. This look was what I felt was more or less the way I saw the world. I looked at the projection of my slide or a qualified print and said: " Yes, that is the way I remember it, that is the way I felt it".
With digital came the more "negative like qualities" even in the JPEGs, because all pictures can be treated to look very differently when I edit them.
And: It was not always easy to set the camera to a JPEG setting that looked like "Fuji Sensia" or "The way I felt the scene".
On the D3 with 1.4/50G I felt "D2X Mode III with sharpening set to value 5" was a very good resemblence of my beloved Fuji Sensia look, but every camera has a different response curve and "Fuji Film simulation" on a Fuji Digital camera does not necessarily look like Fuji Film.
So
If you remember a low contrast scene and want to show it that way: Just do it. If you very sensitively pump the pic a very little bit like our friendly lady from South Africa did, also good.
Make your artistic decision and acquire the editing skills you need to create your vision on screen and paper!
Love
Frank
simato73
« Reply #18 on: August 23, 2016, 21:50:06 »
Frank,
Thanks for your comments. Glad you liked the photos.
I use Iridient instead but the idea is the same. Then I use Lightzone, not Photoshop. I like it, it is simple, it does 99% of what I want and I cannot be bothered learning to use something else. Life is too short and there are so many other interesting (or necessary) things to do.
I used to shoot Provia or sometimes Velvia, but since digital I have never wanted to get the same look from my digital files.
I just work the file till I get something I like.
Sometimes I want to make it look as  I saw it, but other times I try to make it look in a different way, perhaps as I thought it should have looked (but it didn't) when I took the shot.
Simone Tomasi
Lars Hansen
  • Zealand, Denmark
« Reply #19 on: September 01, 2016, 13:56:01 »
Thanks Simone - I'm glad you recieved my feedback that way. I'm definitely no expert and just trying to draw on others experiences and found the discussion interesting.
As for “honesty” - any image is of course a personal interpretation of a given scenery. My point about honesty is that I've often found myself focusing (too much..) on reproducing a scenery as close to real life as possible - then it tends to become more a technical discipline instead of a personal interpretation.
Exactly – and I agree. I think you misunderstood me. I was not suggesting the light was bad and I like the expression the wind creates –  the nature of the light, the shininess as you say. So my point was to even allow it to stand out more clearly. I don't find it flat.
OK – thanks for explaining.  In number 2 the nature of the light/sligtht haze (?) is probably responsible for less tonal contrast in the greens (or is it the mid tones..). I do not find the light harsh in your shots .
Interesting. I might try a similar approach and process Tiffs in antother program – I sometimes find the JPG output in Capture One Pro (Fuji X-E1 files) looking slightly odd. Probably related to sharpening – whether it helps to export Tiffs instead could be interesting to see.
Recently I've spent time using Color Efex Pro that has some interesting profiles/presets - e.g. one for tonal contrast I've used a few times. It only accepts JPG but I sometimes just use it for exploring adjustments and alternative expression.
