Author Topic: !DAILY UPDATES! August. 366 days: your 2016 in photographs  (Read 81186 times)
Re: !DAILY UPDATES! August. 366 days: your 2016 in photographs
« Reply #315 on: August 25, 2016, 12:38:40 »
August 25th 2016  Already hot...
Early autumn?
D800E  75-150/3.5
the solitaire
« Reply #316 on: August 25, 2016, 21:56:56 »
My birthday present arrived yesterday so here is a photo I made for the occasion
A lovely well made camera strap for my Nikon F
Image taken with the 80-200 f4 Ai-S on D3
Buddy
« Reply #317 on: August 25, 2016, 22:12:58 »
Congratulations, Buddy.
Cat in a hot garden 55/1.2 AI
sveintore
« Reply #319 on: August 26, 2016, 08:42:17 »
sveintore: A wonderful, innovative action shot of a different perspective. Thank you!
« Reply #320 on: August 26, 2016, 08:42:53 »
Congratulations, Buddy!
« Reply #321 on: August 26, 2016, 08:43:38 »
John: very unusual bokeh effect. can you explain these lines?
« Reply #322 on: August 26, 2016, 09:29:58 »
Dogtraining tonight :D
sveintore,
Is that a long dog? If so you used foreshortening to good effect!
« Reply #323 on: August 26, 2016, 10:12:18 »
watering the dog
« Reply #324 on: August 26, 2016, 10:16:03 »
Is it love or just awe?
« Reply #325 on: August 26, 2016, 10:20:50 »
ferryman
the solitaire
« Reply #326 on: August 26, 2016, 13:08:30 »
Is that dust on your sensor or are those mosquitos?
Buddy
« Reply #327 on: August 26, 2016, 13:14:38 »
Biology. Definitely. Backlit Biology. Probably insectoid.
sveintore
« Reply #328 on: August 26, 2016, 16:24:09 »
sveintore,
Sadly, she's not that long, not a dachshund. She's a "working" cocker spaniel. (less fur, not for the showring)
Just took a bunch of (boring) pictures at a nosework training session and this happened in a break. Uexpected, but it was the coolest shot of the night :)
the solitaire
« Reply #329 on: August 26, 2016, 17:21:15 »
Frank, I can not explain exactly why these are rendered when they are from an optic engineering viewpoint because my understanding of optical engineering is not up to that level.
But what I do know is that a good example of a lens that reliably renders these "double hard lines" in OoF areas is the 85mm f1,8 AF-D Nikkor.
When at medium distances from the main subject a different subject displays a hard transition between light and dark, then the edge shows up like one of the lines seen in Johns image.
The 50mm f1,2 is more prone to this then the 55mm f1,2 is, but the latter also displays this behaviour with subjects close to, or about 1m away and behind the main subject.
I try to avoid elements in this zone to work around the issue with most fast lenses.
This behaviour is also part of the reason why I like the 5cm f2 Nikkor-S and the 135mm f3,5 Nikkor-Q.C as much. Both are relatively free of these double lines.
Guessing at optics I would say the problem is caused by internal reflections, which also explains why faster lenses, or lenses with bright frontallens groups tend to suffer morepronounced from this behaviour
Buddy
