Author Topic: Wifi for a Df?  (Read 6944 times)
RobOK
    • My gallery
Wifi for a Df?
« on: July 13, 2016, 16:06:59 »
Hello, my daughter's D5500 has wifi capability, that it is nice to pull one or two shots onto a phone, small edits, and publish. Is there a way to accomplish this with a Df?  I think the WU-1a could do this correct? Has anyone used this successfully and recommend it?  I don't like having an extra piece, but I think the convenience would be nice.
Thanks
Rob.
abergon
    • Portfolio
Re: Wifi for a Df?
« Reply #1 on: July 13, 2016, 16:17:30 »
Hello,
I bought the wifi dongle for the Df. It's cheap compared to Nikon adapters for other cameras, and it does the job. It's also small, to the point that you may lose it easily. After having played around with it a little bit, I don't have a lot of use for it.
RobOK
    • My gallery
Re: Wifi for a Df?
« Reply #2 on: July 13, 2016, 16:19:53 »
Yes, I think this will be very occasional use, so low cost is good. Some accessories that say they work with Df can be quirky (maybe more third party), so mainly wanted to confirm it works as expected on Df.
Re: Wifi for a Df?
« Reply #3 on: July 13, 2016, 16:21:34 »
I use the port for a blue-tooth based GPS device from Foolography.com instead. Much much more useful.
Re: Wifi for a Df?
« Reply #4 on: July 13, 2016, 17:02:06 »
Nikon's genuine WU-1a wifi adapter for Df stick out from the camera body in a very odd and flimsy way.  So, I don't think it is very comfortable to use.
The unit Bjørn uses looks much smaller and more unobtrusive.  An Eyefi SD card may be worth looking at, too:
http://www.eyefi.com/
paul_k
    • Paul_k
Re: Wifi for a Df?
« Reply #5 on: July 13, 2016, 18:33:43 »
Recently got a WU1a with the 2nd hand D7100 I picked up, which also works with the DF
Agree with the observation on the odd way t sticks out, doesn't make the camera  very comfortable to hold
Have been using Eye F Mobi cards with all my Nikons with SD slots (D800, DF, D7100), there is a SD to CF adapter but that lony works with a CF II card slot (which as I understand it is somewhat wider then a CF I slot) Got one, but haven't been able to get it to work with my D3 (that would have needed an update of my OS to El Capitan, and I'm not willing to risk that)
The cards work well, but you''ll have to live with its limitations e.g.
- basically only usable with 'JPG small' files (there is the Eye Fi Modi Pro which 'can' handle RAW files, but in my experience that takes ages per individual fies. Only shooting wire tethered is really fast enough for handling/transferring RAW files)
- having to regularly 'tickle' the Wifi connection to wake up and stay connected/get reconnected
- no 'instantaneous' transfer (takes about 5 seconds between taking the shot and full transfer of the jpg. That said, if you shoot a series and the Wifi connection is made, the files are transferred in a sequence quite fluently, without delay, one after the other)
- pretty flimsy built quality
The latter IMO is quite understandable.
It's basically only two very thin plastic halves which have to hold the Wifi bit as well as the memory, yet only be as thick as a regular SD card.
So after prolonged use/taking the card out of the camera all the time, you may risk tearing the two halves apart and consequently breaking the card (happened to me with my first card).
Solution is pretty simple though (if maybe not factory recommended)
Before the first time you use the card just stick a small, thin strip/piece of sellotape on it to 'tape' the two halves together. The tape can stay there and will prevent the card halves from falling apart in the long run.
But it's very convenient when eg working with a model, stylist, art director, to be able to show and discuss pretty fast after taking the shot what it looks like on a large screen (like a smartphone or tablet) without having to have an (expensive/big/heavy) laptop around.
I also use it when shooting events like eg catwalk, being able to show the results immediately after the show is a great way to make an impression
With a DF (which only has one card slot) it will have to take both jpg and RAW files, no problems with the writing speed though (on the D800's and D7100 I use one 'normal' card for RAW, and the Eye Fi just for basic jpg's).
Downloading the files (just jpg's, or jpg and RAW) from the card to the computer with a 'normal' card reader doesn't work in my experience (but I just use a humble HAMA 2.0 35-in-1)  .
Fortunately I have a Macbook which has a SD slot, but there also are special Eye Fi SD to USB adapters for sale (prices are pretty cheap)
RobOK
    • My gallery
Re: Wifi for a Df?
« Reply #6 on: July 13, 2016, 19:00:59 »
Well the goal is to move a small number of photos to a phone or iPad without syncing to a laptop. Nevertheless the GPS is interesting too. So then you have to carry a GPS receiver in your pocket too or can it work off of a smart phone?
thanks!
RobOK
    • My gallery
Re: Wifi for a Df?
« Reply #7 on: July 13, 2016, 19:03:57 »
I was thinking I would only plug the dongle in periodically on a break, not in there full time while shooting.
Appreciate feedback from both above on the precarious nature of the WU1a.
Re: Wifi for a Df?
« Reply #8 on: July 13, 2016, 19:27:32 »
If you are only transferring files periodically why not a cable? The are cables for Android and iPhone and tablets.
paul_k
    • Paul_k
Re: Wifi for a Df?
« Reply #9 on: July 14, 2016, 00:13:25 »
Just remembered, the guy I got the WU1A from also told me the original Nikon App is a pain.
There apparently are 3rd party ones around that work much better (no personal experience, so I can't recommend any)
RobOK
    • My gallery
Re: Wifi for a Df?
« Reply #10 on: July 14, 2016, 04:53:31 »
Sounds interesting, can you point me to more? What App would I use?
Re: Wifi for a Df?
« Reply #11 on: July 14, 2016, 07:39:12 »
Into the same context I'm using the WU-1b WiFi dongle with my D610.  I'm using it into the sole context of piloting my focus stacking software from my iPad (Helicon Remote http://www.heliconsoft.com/heliconsoft-products/helicon-remote/ ).  Nikon's WMU (Wireless Mobility Utility) is a worthless, badly written, piece of software.
Re: Wifi for a Df?
« Reply #12 on: July 14, 2016, 07:49:28 »
As owner of D750, I share the same experience with WMU.  This dumb software make the integrated wifi of D750 useless, as it doesn't work with Camera Control Pro 2 or the newer and (brobably only slightly) better Snap Bridge.
I also personally call WMU "Worthless Mobility Utility".
BW
    • Børge Wahl-Photography
Re: Wifi for a Df?
« Reply #13 on: July 14, 2016, 08:21:15 »
I have tried a program called Airnef. The few times I have used it it has worked like a charm. For transferring NEF-files to my computer.
Re: Wifi for a Df?
« Reply #14 on: July 14, 2016, 08:38:33 »
Here the link to Airnef: http://www.testcams.com/airnef/
Personally, I use the KISS method: taking my memory card out of the camera and plugging it into my computer 😊
