Author Topic: !DAILY UPDATES! July. 366 days: your 2016 in photographs  (Read 91382 times)
Re: !DAILY UPDATES! July. 366 days: your 2016 in photographs
« Reply #45 on: July 04, 2016, 21:54:28 »
D3 very nice camera with a film like rendering, it appears to me the d700 was a more modern camera.
« Reply #46 on: July 05, 2016, 06:00:42 »
The D3 has rather cool tones but very consistent. If you know her you know how she will show
the colors.
the solitaire
« Reply #47 on: July 05, 2016, 17:45:58 »
With the D3 I use rhe "cloudy" WB setting by default. In most situations I hardly need to adjust WB afterwards.
One thing I like about the D3 files is that I can recover almost 3 stops out of the whites/bright areas. Compared to the D800 it makes sense to expose for the shadows where the D800 should clearly be exposed for the highlights.
On one side that is an odd choice because it also means that the D800 allows shorter exposures times which would again be beneficial for action photography.
The D3 on the other hand shows the tendency to produce a recoverable sky in nearly all situations
Buddy
« Reply #48 on: July 05, 2016, 19:22:51 »
"cloudy" as default ... never came up with that idea!
I use "A" and several predefined settings I custom measured for several situations
« Reply #49 on: July 05, 2016, 19:51:55 »
That's not my experience with the D800E.  I can recover also a  lot of stops out of the whites and bright areas, which is the reason I always underexpose.  Also valid for the Df.  The D700 had much less dynamic range.
« Reply #50 on: July 05, 2016, 21:30:59 »
July 5
D3 24mm f/1.4g @f8
« Reply #51 on: July 05, 2016, 21:44:42 »
July 5th
D800E  -   Voigtländer APO Lanthar 90/3.5  @f/8
« Reply #52 on: July 06, 2016, 00:00:38 »
Great light, Fons
The fence? Strange, John.
« Reply #53 on: July 06, 2016, 00:11:25 »
A double fence before the passing train.
« Reply #54 on: July 06, 2016, 10:14:57 »
catching up with yesterday:  "Entanglement. False Color Remix."
« Reply #55 on: July 06, 2016, 16:56:13 »
July 6
« Reply #56 on: July 06, 2016, 16:59:13 »
« Reply #57 on: July 06, 2016, 17:05:55 »
your daily dry bread
« Reply #58 on: July 06, 2016, 18:31:20 »
July 6th 2016   Clouds and Sunny  -  warmer weather approaching...
Street decoration.
Lars Hansen
  • Zealand, Denmark
« Reply #59 on: July 06, 2016, 19:26:23 »
July 6. A windy day.
#1 BIF by accident. #2 Not BIF, but on purpose. #3 Rowing against the wind.
