Author Topic: Lenses That Work with Bellows  (Read 3989 times)
« on: June 20, 2016, 19:23:41 »
What are some of the lenses you use or have used with bellows or technical cameras and the Nikon Cameras? Here are ones that I know work. Let me know of others please, that you would suggest.
El Nikkor 105mm f/5.6 APO
Nikkor AM-120mm f/5.6
Macro Nikkor 120mm f/6.3
Macro Nikkor 65mm f/4.5
Nikon PC-Auto 105mm f/1.2
Carl Zeiss S-Planar 74mm f/4
Nikkor-P 105mm f/4 Bellows
Printing Nikkor 95mm f/2.8
Printing Nikkor 105mm f/2.8
Printing Nikkor 150mm f/2.8
Re: Lenses That Work with Bellows
« Reply #1 on: June 20, 2016, 19:34:07 »
The first versions of the Bellows-Nikkor 135 mm f/4 Nikkor-Q come to mind. Like the shorter successor, the Bellows-Nikkor 105 mm f/4 P, they all focus to infinity.
I think it's important to keep in mind that most lenses can be mounted on bellows.  For shorter focal lengths, they have to mounted in reverse , otherwise the focus plane gets inside the optics. A little impractical alternative ...
On an FX camera, lens heads with a focal length from around 90 mm can reach infinity if the bellows device can be sufficiently compressed.
The best alternatives are lens 'heads', i.e. optics without a focusing helicoid. In order to manipulate the aperture, the lens in question either has to have a manual aperture ring, or the aperture can be set through an adapter.
« Reply #2 on: June 20, 2016, 19:45:57 »
When you have time, I would love some nitty-gritty details on all of this, if you will. I get the idea, but would appreciate some chapter and verse, if time permits.
« Reply #3 on: June 20, 2016, 20:18:18 »
thank you Bjørn!
As I know price is not something that holds you back, Michael, you might be interested in the Schneider APO Digitar series:
https://www.schneideroptics.com/ecommerce/CatalogSubCategoryDisplay.aspx?CID=202
and the corresponding Rodenstock Digaron line:
http://www.rodenstock-photo.com/de/produkte/fachobjektive-digital
IMO these lenses are the best money can buy, apart from some motion picture glass, military and custom in space astro optics
« Reply #4 on: June 24, 2016, 09:50:07 »
thank you Bjørn!
Frank, of these very expensive lenses, which would be best for close-up work on the Cambo Actus. How is the Scneider APO-SYMMAR 120mm f/5.6 lens different from a Super Symmar, if you know?
« Reply #5 on: June 27, 2016, 01:43:46 »
Read Here about it: https://www.schneideroptics.com/pdfs/Digitar.pdf
« Reply #6 on: June 27, 2016, 03:30:48 »
I read there what I could. But is this a key lens for DSLR size camers or some other focal length?
« Reply #7 on: July 01, 2016, 10:09:30 »
Medium / Large format coverage and for Tilt/Shift applications due to their large image circle -
why elso would I have posted it then?
