Author Topic: Nikkor 105mm f/2.5  (Read 33235 times)
Re: Nikkor 105mm f/2.5
« Reply #45 on: August 29, 2016, 00:23:49 »
The 105/2.5 gets better with distance.  It's shortcomings are really magnified at it's MFD.
« Reply #46 on: August 29, 2016, 03:40:13 »
Tristin, that is interesting.  My experiences with a couple of different versions of 105/2.5 (all were of Xenotar type.  Single-coated, multi-coated K, Ais) equally tell that they are sharper at MFD.  None I've had was satisfactory when focused at distant scenes.
« Reply #47 on: August 29, 2016, 04:52:02 »
some people say that a 100X multiplication factor of FL = distance is the optimum distance for a lens :o :o :o
example:
50mm = 5 meters
85mm = 8.5 meters
« Reply #48 on: August 29, 2016, 06:33:13 »
Akira, I particularly mean the lense's field curvature and chromatic aberrations which are much more noticeable up close.  The sharpness of the 105/2.5 is good up close, but the area in which the field curvature will allow sharpness plunges strongly in the corners and brings increased CA with it making the image corners and borders look poor.  At farther distances the field curvature effects the image less prominently.
« Reply #49 on: August 29, 2016, 06:48:09 »
I see.   I guess the lens designers thought the mid-teles would be used for the portraits more often than something flat in the entire frame when focused closer.  So, the field curvature could be a bit tolerated.
« Reply #50 on: August 29, 2016, 06:50:19 »
example:
50mm = 5 meters
85mm = 8.5 meters
I think the lenses without CRC at that time was basically designed for the infinity focus except for Micro Nikkors.  But the balancing of the aberrations in different distances should have been dependent on the designers' taste.
« Reply #51 on: August 29, 2016, 07:44:15 »
Precisely.
simsurace
« Reply #52 on: August 29, 2016, 12:50:27 »
example:
50mm = 5 meters
85mm = 8.5 meters
Do these people also explain why they think so?
Simone Carlo Surace
suracephoto.com
« Reply #53 on: August 29, 2016, 12:55:19 »
example:
50mm = 5 meters
85mm = 8.5 meters
Are the "some people" the folks gathering at tokinon 50/1,4?  ;)
« Reply #54 on: August 30, 2016, 07:12:34 »
no, i think it was Sato Haruo himself who said that. :o :o :o
read the 5cm or the 5.8cm write up i think it's there
« Reply #55 on: August 30, 2016, 07:13:18 »
I don't recall but I read it from a credible source. I just cannot remember where :o :o :o
« Reply #56 on: August 30, 2016, 07:40:30 »
Just checked "1001 Nights".  I couldn't find any of the notion at least in the sections for 58/1.4, 55/1.2, 50/1.4 or the rangefinder 50/2.0.  I'll look into other sections when I have time.
« Reply #57 on: August 30, 2016, 07:42:13 »
me,too :o :o :o
« Reply #58 on: August 30, 2016, 07:53:09 »
stenrasmussen
« Reply #59 on: September 07, 2016, 09:35:45 »
Ai-S version at f/2.5.
