Author Topic: Nikkor 105mm f/2.5  (Read 32246 times)
tdoan
  • From the land of Happiness
Re: Nikkor 105mm f/2.5
« Reply #30 on: July 13, 2016, 13:13:24 »
you should buy all 5 versions  :o :o :o!
1: tickmark
2: chrome nose sonnar version
3: new-nikkor
4: Ai
5: Ai-S
That's good! everything has a start
Of course I have to start at the bottom.  I picked up an Ai-S :D but as I am leaving on a trip tomorrow and won't be back until the end of next week, it will have to sit on a shelf at the local post office, waiting for me.  Poor babe.
This is the babe on a pedestal :) http://www.ebay.com/itm/Nikon-Nikkor-105mm-f2-5-Lens-for-Nikon-35mm-SLR-Cameras-/122018797628?nma=true&si=%252BJXXdKxdfFZwOaj%252FbS8HesIyQPk%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
btw, you, Rick, are one of the absolute worst.  I keep reading your blog and having flashes of myself, branding my new Vessel, threatening the lenses "If you don't behave, I am going to take you apart and I know just how to do it ... I think.." :D Yes, me, the mad lens hacker :D
Quote from: Bjørn Rørslett
Nikon S-mount rangefinders
of course when master Bear speaks, I have no idea what he is talking about and have to google it :) Thank goodness for Google.
Quote from: tommiejeep
I'm in the same boat with 135mm lenses
Here they go again with the flauntings ... I am going to have to report you to the moderator :D  Truth be told, I had a 135 f2 on watch, debating between that and the 105 2.5
Quote from: richardHaw
i am looking for a cheap "mountain nikkor" for myself
::) aren't you there already ?  Me, I will just have to build one myself.  Been practicing this song to my wife "Just one more lens honey ..."  :P
Tien Doan
« Reply #31 on: July 13, 2016, 13:24:35 »
Even the more "modern" Ai-s version is an incredible "convenient" lens... :-) Here musing with chairs at a café's terrace at f/5.6 !
Terrasse... by ArchiVue, sur Flickr with Df and 105mm f/2.5 AI-s
« Reply #32 on: July 13, 2016, 14:00:39 »
The reference to the "mountain Nikkor" is to the 105 mm f/4 Nikkor-T that lived a very brief life around 1960. It was, as indicated by the "T" designation, a triplet optic that conferred a slim, lightweight barrel. The lens used tiny 34.5 mm filters and had a cute preset aperture ring in front and an even cuter little snap-on lens hood.
The name 'mountain' was fetched from the contemporary Mountain Elmar 90 mm f/4 for the Leica M-series. Such lenses were aimed at photographers wishing to travel light-weight.
As far as I recall, there were versions for the F and S mounts concurrently and they in fact only differed in their mounts, as the optics  are identical. Th
I have a nice sample of the F-mount 105/4 T, with CPU of course ... Not a top performer by today's standards, but gets the job done discreetly. It can also do UV passably.  Must been 10-15 years ago I got it and it was not very expensive at that time. However, I refrained from getting the S version as asking prices were pretty high back then.
Briefly looked in my archives and found a few more recent images obtained with the 105/4 T. Here is one,
« Reply #33 on: July 13, 2016, 15:41:23 »
Hi, you can request for a tear-down guide if you need to. i have 3 versions of that lens in my notes :o :o :o
just make sure that you have the right tools and a steady hand and you're safe. watch professionals work in youtube as well, that will help a lot.
« Reply #34 on: July 13, 2016, 15:44:59 »
The T-Nikkor is so simple there is no need for any disassembly and if required, I trust Erik does this with utmost ease. The CPU modification I managed myself.
« Reply #35 on: July 13, 2016, 15:57:27 »
i just want to open one just for the heck of it :o :o :o
the 105mm is my entry drug. i started with that lens, now i have 5 dryboxes full of stuff
« Reply #36 on: July 13, 2016, 16:00:36 »
Small correction.  The Leica lens nicknamed "Mountaim Elmer" was actually an L-mount 105mm/f6.3 lens.  It was also of a Tessar type unlike the Triotar type on which Nikkor 105/4.0 design was based.
« Reply #37 on: July 13, 2016, 16:24:59 »
Well, Leica-lore is obviously not my force. But the 'mountain' concept was of a small, light-weight lens longer than a normal one. Their outline would be somewhat similar. The T-Nikkor was "much" faster though, a whopping 1.3 stops ...
« Reply #38 on: July 13, 2016, 16:31:04 »
that is OK. the 105's are not rare at all unlike the 5.5cm which is starting to become even rarer even here in japan :o :o :o
« Reply #39 on: July 13, 2016, 16:55:02 »
When the Mountain Elmar 105/6.3 was released in 1932, the 90/4.0 Elmar was housed in a fat lens barrel, unlike the later slim ones released in 1933.  Thus the "small and light-weight design" only applied to the 105/6.3 then.
« Reply #40 on: July 13, 2016, 20:08:44 »
 But I don't think you can call the Sonnar a Gauss design.
Correct.
The earlier design is the Sonnar-like one; the later design is the Gauss-like one.
chris dees
  • Amsterdam
« Reply #41 on: July 13, 2016, 20:42:42 »
These are my 3 105's all in mint condition and working fine on my Df.
Nippon Kogaku Nikkor-P Auto 1:2.5 F=10.5cm Sonar from 1963
Nikkor-PC Auto 1:2.5 f=105mm AI-ed (Chipped by Eric) Gauss from 1973
Nippon Kogaku Nikkor-P Auto 1:2.5 f=105mm Sonar from 1971
Chris Dees
« Reply #42 on: July 13, 2016, 22:33:08 »
Not only that, they also belong to the same serial number block, that is, Nikon made one set of serial number rings which were used for the F or S mount lenses.
During the rangefinder era Nikon often made lenses in multiple mounts - S, M39, Exacta, Contax - all belonging to the same serial number block. The Nikkor-T 10.5cm is the only example I know of where F and S mount lenses share the same serial numbers.
ArendV
    • flickr
« Reply #43 on: July 13, 2016, 23:48:16 »
Correct.
Thanks Pluton for confirming this !
Arend
« Reply #44 on: August 28, 2016, 23:02:20 »
The more I use it, the more I like it. Here another usage - shooting mosaics in the pretty dark church of Santa Maria Maggiore, Rome. Df, 12800 ISO, 1/125 handheld, wide open.
The keeper rate with such settings is near 100% on static subject : the Df + lens is heavy enough, and the "quiet" mode is also useful to keep vibration low.
At f/2.5, the lens is sharp and contrasty enough for the Df, at least when the subject is not too close. Here is an example (with 100% crop). Distance from subject may have been 10-15m.
Earlier I thought that f/2.5 was rather for slightly soft portraits, but no.
